Cant Fill My Tank Up!!
Old Jan 5, 2005 | 04:26 AM
ZpikeZ's Avatar
ZpikeZ
It happened to me the first time yesterday at 19,000 miles.
Old Jan 5, 2005 | 12:06 PM
code350z's Avatar
code350z
I've noticed this same problem but with a twist. It always happens at Arco ... never happened to me at chevron or shell. So i stick with chevron.
Old Jan 5, 2005 | 01:18 PM
Jun's Avatar
Jun
well, i took it the dealer, went with the mechanic to the gas station to fill it up. Proved him the problem. They ordered a new fuel pump. I'll let you guys know if that solves the problem.
Old Jan 5, 2005 | 05:56 PM
pacificwindsurf's Avatar
pacificwindsurf
I've found the problem seems to pertain to the gas station, and not the car. I've encountered some gas stations that have tremendously powerful gas pressure, and it simply loads too quickly and backs up and then shuts off. I have to fill the tank at 1/4 power and that takes forever. When I simply went to a different station I didn't have that problem.
Old Jan 5, 2005 | 05:59 PM
pacificwindsurf
Oh by the way, I've had terrible experiences at Arco. Their gas is terrible (once in my truck it totally ruined the carburetor.) The truck didn't run the same almost immediately after filling up at Arco. Someone told me there may have been water in the tank. I've also had clerks there steal money and argue when I've paid at the counter. And, they don't accept credit cards at the pump, so if you do pay with an ATM card you have to make two trips to the payment maching in the middle of the terminal ... I could go on and on. Basically they have the cheapest gas and cheapest facilities.
Old Jan 5, 2005 | 06:30 PM
tacomaboy's Avatar
tacomaboy
How can you say its the station and not the car? If it were the station, then every car that bought gas there would have this problem!
Its the car... it may only happen at certain stations, but its still the car.
Took mine to the dealer. They act as if they had never heard of it, which is B.S. But they claimed there is no TSB for the 04s. As you can tell it pisses me off.
Still love my Z though
Old Jan 6, 2005 | 06:14 AM
devildoc's Avatar
devildoc
Another vote for the same problem. What's strange, the problem went away for a couple months and just came back yesterday. Go figure?
Ian
Old Jan 9, 2005 | 08:48 PM
code350z's Avatar
code350z
I've had my Z for over a year now and the pumps at chevron and shell don't have this problems. Maybe i'm just lucky...maybe the shut off sensors are different for every pump. I've also had problems like this before with my honda at Arco.
As for the car, I do notice that when I set the pump in the fill tank it tilts up higher than most cars. Could be where it's placed right on the fender where it flares out.
just my 2cents.
Old Jan 9, 2005 | 10:50 PM
RedShft's Avatar
RedShft
well i FINALLY did it!! i was able to get a full tank today with yalls help. just gave it low pressure the whole fill and i topped it off with ease....even though it took 2 hrs(exageration), it got a full belly!! w00t!!
Old Jan 10, 2005 | 02:35 PM
dkny_boi's Avatar
dkny_boi
If you pull the nozzle out a bit and fill it till it clicks off... then fill it more slowly, can you see the fuel almost overflowing, so that when you let go it'll slowly drain down?
If that's the problem you have, don't inconvenience yourself all the time, take it your dealership to have it fixed. Mine told me it was a problem w/ the fuel check valve (the one that closes so fuel doesn't spill, but opens when you refuel), which they went on to replace under warranty. I went from having the problem every single time i tried to fill up (no matter which station), to being able to pump full pressure no matter how much fuel is in my tank.
Old Jan 11, 2005 | 09:23 AM
sq40's Avatar
sq40
Same Problem Here, '04 Roadster
Old Jan 11, 2005 | 11:51 AM
tacomaboy's Avatar
tacomaboy
Thats what I thought my problem was, unfortunatly my dealership is not as friendly/helpful/honest as yours and denied it was a problem with this vehicle. They took it for a fillup, and like an idiot I did not go with them. They said it filled fine. Do I believe them? No. Can I prove it? No..
Do I want these ****** removing my tank? NO!
Old Jan 14, 2005 | 12:00 PM
Asterix's Avatar
Asterix
I think I found the problem.
While visiting my shop that's fixing my Supra, I saw a Track Z on the lift. I asked what was up and they said that someone put diesel fuel into the car by mistake, so they were removing the tank to flush and clean it. They got to remove the differential and part of the exhaust to get to the tank.
Well, the tank is like a saddle over the differential. What this means is if you fill too fast, the filler side of the tank gets full first, then the pump shuts off.
Pump more slowly once you're over half full so the gas doesn't splash back and shut off the pump. I'd guess that some pumps pump faster than others, so the fast ones give the most problem.
That's how Nissan crammed a 20-gallon tank into our little car.
Asterix
Old Jan 14, 2005 | 12:46 PM
Synergy350Z's Avatar
Synergy350Z
Happened to me for first time last night, I almost threw the hose on the ground and darted off. Guess that's what 4 hrs of sleep and 25 hrs of work will do to ya. Thanks for the tip though.
-Travis
Old Sep 12, 2005 | 08:13 PM
Bigmikeny21's Avatar
Bigmikeny21
Yeah i've noticed this problem too...its funny though it only happens at certain gas stations if i remember right...but its a pain in the ***...the best thing to do is barely squeeze that last half or qt of a tank and it'll fill...ive just about topped it off that way...pulling the nozzle out a few inches helps too
Old Sep 12, 2005 | 10:29 PM
elms350Z's Avatar
elms350Z
I had the same problem but it went away...try different gas stations
Old Sep 13, 2005 | 12:10 AM
04350zTouring's Avatar
04350zTouring
never had this problem on my Z, then again just got it today. Can't even sleep in excitement. I guess i will fill it up tomorrow and we will see. Keeping fingers crossed and hoping it doesn't happen to me.
Old Sep 13, 2005 | 12:13 AM
  #38
Leslie's Avatar
Leslie
I only fill up at Chevron and it happens different pumps and stations, but when It does, I just turn the nozzle upside down, like I see many others do now, no problems at all since. It happened to me at the first fill up, good thing my husband was there at the time he rides motorcycles and it seems the "turn the nozzle 180 deg is a trick they do as well".
Strange tho as why it happens at some gas stations and not at others, even now when I go to the same station and the same pump on one day would give the problem and then another day it wont, LOL guess the Z is real picky when it comes to fuel tank pressure/air flow etc.
May 12, 2016 07:42 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
TrackFiddy
Sep 24, 2015 11:40 PM
CJs_Z33
Sep 18, 2015 12:06 PM
