04 Alignment spec values
I know this subject has been beaten to death, but, I cant seem to be able to find a full set of current alignment specs on the forums. I have found partial settings, but, nothing definitive, complete and most recent.
I would like to start a discussion to document a complete and most current set of alignment specs for our Zs.
I just had an alignment done on my Jul 04' build date Z and these are the settings the dealer stated came out of their machine and are supposedly up to date settings (based on mechanic I spoke with.)
They use a Hunter alignment based on service writer discussion.
I typed the values into the table verbatim including the title which indicates the settings are for a 2003 Z.
I have my doubts based on the toe in values of .04 with a +/- tolerance of 0.04. I was under the impression, 0 tolerance was new setting for toe-in (if I am reading the values correctly.)
I am a total novice to alignment values (I just drive 'em.) so lets keep it simple
Code:
Nissan: 350z: with 17" Wheel : 2003
*Note values are in degrees '
Left Front Right Front
Spec. -Tol. +Tol. Spec. -Tol. +Tol.
-0.6' 0.8' 0.8' Camber -0.6' 0.8' 0.8'
8.2' 0.8' 0.8' Caster 8.2' 0.8' 0.8'
0.04' 0.04' 0.04' Toe 0.04' 0.04' 0.04'
5.1' 0.8' 0.8' SAI 5.1' 0.8' 0.8'
4.5' 1.5' 1.5' Included Angle 4.5' 1.5' 1.5'
Front
Spec. -Tol. +Tol.
Cross Camber 0.0' 0.8' 0.8'
Cross Caster 0.0' 0.8' 0.8'
Total Toe 0.08' 0.08' 0.08'
Left Rear Right Rear
-1.6' 0.5' 0.5' Camber -1.6' 0.5' 0.5'
0.04' 0.03' 0.03' Toe 0.04' 0.03' 0.03'
Rear
Spec. -Tol. +Tol.
Total Toe 0.08' 0.06' 0.06'
Thrust Angle 0.0' ..... ....
