Gotta "shift"
Old Nov 10, 2002 | 02:34 PM
jim911's Avatar
jim911
Angry Gotta "shift"
WHAT'S MAKING THIS "SHIFT BOX" SO NOTCHY? IS EVERYONE'S CLUTCH ADJUSTMENT ABOUT AN INCH OFF THE FLOOR?
Old Nov 10, 2002 | 02:40 PM
ares's Avatar
ares
Veteran
yeah mines like starts engaging about an inch off the floor. fine and dandy, and SLOWLY engages not enough to really go anywhere, but enough that it would grind. then at like half way it engages to like 95% in a few millimeters, and then finally it takes the rest of the way to lock in that last little bit.
I just kinda thought this was normal. and the shifter has a click or 2 depending on the gear before its really in the gear. youll notice that if your clutch isnt down you cant get past that click, like it you do it with the car off, and just try to put it into first, then that click becomes a lock.
Old Nov 10, 2002 | 02:53 PM
jim911's Avatar
jim911
YEAH, I'LL HAVE TO SAY THE ONE I TEST DROVE WAS THE SAME WAY BUT I GOTTA TELL YA I'M NOT CRAZY ABOUT IT. ONCE YOU'RE UP AND RUNNING IT'S GREAT BUT IT'S THAT STOPLIGHT TO STOPLIGHT I DON'T LIKE. ONLY 200 MILES SO FAR , MAYBE THERE'S HOPE!
Old Nov 10, 2002 | 03:40 PM
Brad4rdHay's Avatar
Brad4rdHay
Don't worry man. Fisrt you will get used to the clutch. Once you get it, its perfect. It was a little odd for me to for the fist 500 miles or so.
Second, the shifter is much stiffer when new. Mine really lossened up around 1300 miles. Once it does, its much easier to shift but still has that bolt action "snick-snick" feel. Also, this shifter isn't great when forced, just use enough to get it to the next gate.
Old Nov 10, 2002 | 03:42 PM
daytona350z's Avatar
daytona350z
yea what he said... i also started out with about an 1in off the floor engagement, but at 300 miles now it gets better everytime i drive it.. dun worry about it...
P.s. please turn off caps lock, it looks as tho you are yelling...
Katie93
Sep 15, 2015 05:57 PM
JZC
Cleaning & Detailing
Jan 24, 2003 11:02 AM
nwind21
Nov 5, 2002 12:48 PM
3502GO
Oct 18, 2002 12:21 PM
