Synthetic Voids our Warranties?!
Originally posted by Kray Z
The better the filter less than 10 microns is the best in a synthetic cellulouse filter. You can get. External filters that will go to 2-3 microns rather than 20 micron full-flow filter.
Originally posted by yobri
Check your oil levels periodically... if they keep getting lower and lower over time, you either have a leak or are burning oil.
Also, check to see if your exhaust smoke is a bluish color...
Oh, and David McDavid is.....?
Originally posted by Z BOY
i drive my z hard all the time and have to add oil prolly every two wks, but my garage floor is clean, so i guess i am not leaking but burning?
Originally posted by 350ZTwinTurbo
i was told by my tech today that if i run synthetic oil in my car, the warranty on the entire engine is void. wtf? why would that void it? he said if i run it, just dont tell them. also, where can i take my old oil to dispose of?
You should tell the tech that most over the popular counter "synthetics" (except Mobil 1) in the US are Group III Hydrocracked based...so they aren't really synthetic (PAO or Ester) at all.
I have been running PAO based oil for 20,000+ miles in my Z..no problem.
my nissan mechanic told me yesterday he would use synthetic oil at my request without question. he also said it is better than dyno oil.
Anyone have a recommendation on regular oil brand for a first oil change....I'm going with either a K&N filter or a Mobil 1 filter and probably Valvoline unless I hear otherwise from you guys...
Thanks,
RV
BTW, Great info Kray-Z
Thanks,
RV
Mobil one is a good choice. Really it doesn't matter all of the oils perform so close to one another your paying the extra money for marketing.
Without seeing a UOA or VOA of the oil you'll be using i would recommend using whatever you feel like.
Without a true baseline and numbers. Which oil is the best? If you can answer that without any proof you must be god.
Go with mobil one or something with a PAO base. Its a true synthetic if your thrifty and want something decent and better than dino oil go with castrol or supetech full synthetic.
seagrasser
Oct 11, 2015 03:27 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
