Base model w/o limited slip differential... Is it needed?
on
LSD
To Cabilistic Fire : I agree with everything you said . What I was implying was that unless you were the type to later put in a mechanical LSD , the loss of how much horsepower you could put down would probably be indistiguishable to most drivers except under unique conditions ( they would also be the type of driver who would most benefit from traction control probably more the a good LSD) . I was basically talking about tranferring power both from a standing start and while cornering . Sorry ,I guess you somehow inferred that I was talking about increasing horsepower , rather than maintaining it . Transferring as much horsepower as is available is also one of the important benefits to me while optimizing the handling you mentioned . In driving my base Z I have found little value to the present LSD and do plan to upgrade .I don't feel the aftermarkets will be as high as you predict . either . Also , you should then have a better responding LSD than you have in your Z now that will produce the results you were speaking of while simultaneously utilizing most of your horsepower available .
on
Originally posted by Daytona
Guys,
I plan to install a Cusco Type MZ 2-way on my base model hopefully before Christmas, so I'll let you all know how it goes...
Guys,
Charter Member #40
on
What will the NISMO diff be?
According to this article at cars.com
http://www.cars.com/news/stories/111302_story_an.jhtml
The Nismo car is equipped:
"The car features an exhaust system that increases horsepower to 295 and torque to 280 pounds-feet. The 350Z also has a high-performance air filter and oil cooler, lightweight flywheel, limited-slip differential and racing clutch. The suspension has improved coil springs, shocks and sway bars. An aero kit is included. "
Does this mean that NISMO will carry a replacement differential? Based on the rest of the article they claim that they will support full factory warranty on dealer-installed Nismo parts since these exist already in the japanese market. So does anyone know what they currently sell in the Japanese market?
Originally posted by nj1266
Is that a clutch type LSD? Do you have a link to the company that makes it?
www.cusco.co.jp , although it helps to be able to understand Japanese.
The Type MZ is a clutch-pack type LSD.
Re: What will the NISMO diff be?
on
Getting the base model:
I am adding True Xenon's (379Shipped) @ Misterjung.com
comes with Ballast Power supply / Phillips bulbs. Many to chose from (color / brightness)
leather trim kit for 500 shipped.
LSD isnt important for me right now, but I can always do an aftermarket install if i needed too. Not bad for say 9 bills though =]
on
You don't gain hp
To cabilisticfire ( great name by the way ) ,
What I was referring to was the Loss of traction and the accompanying Loss of horsepower primarily off the line . How did you get " gaining horsepower " out of that ? It seems D'Oh understood it clearly enough ! By the way , sorry cabilistic, it's " lose horsepower" not" loose horsepower ".
FrankieZZ
Hampton Beach, NH
Silverstone 6M
PS I still say you are better off with an aftermarket LSD than the one available on the non base models
FrankieZZ
Hampton Beach, NH
Silverstone 6M
on
Re: You don't gain hp
[i]PS I still say you are better off with an aftermarket LSD than the one available on the non base models
I run a Quaife on my race car and it is way better than the viscous that comes stock with the old Sentra SE-R. The new Sentra SE-R Spec V get a mechanical LSD from the factory. I am jealous
