tractions control kicks in when im not slipping
Old Apr 11, 2005 | 10:34 PM
zmespeed's Avatar
zmespeed
Default tractions control kicks in when im not slipping
ok ive got the 2003 enthusist edition and i can just be going down a road strait and say im in fourth and i floor it, some times the tcs kicks in and im like "what the f***". it just seem s kick in way to much even when the tires arnt slipping. i think the tcs compares speed of the front and rear tires and then does its duty based off the info, but if any thing my back tires are bigger than my front causeing them to rotate slower so the car should not think im slipping, any answers?
Old Apr 12, 2005 | 06:06 AM
Low J.'s Avatar
Low J.
do you have stock wheel and tire sizes?
Old Apr 12, 2005 | 09:24 AM
raycs7's Avatar
raycs7
Default Slip message
This happened to me for a month until I decided to check the brake fluid reservoir...
As the pads wear, the level falls.
When it is low enough, TCS and slip light kicks in during acceletation..
Ray
Old Apr 12, 2005 | 02:44 PM
zmespeed's Avatar
zmespeed
all stock on the wheels and stuff. i have not checked the brake fluid but i just got knew pad put on. it did this before the new pads and after, but i will check the brake fluid anyhow. i dont understand how it is related to acclerating tho.
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
