39778 Miles + Stock tires =.......
Old Apr 22, 2005 | 12:13 AM
330R's Avatar
330R
Originally Posted by bodayguy
a lease says you have to return the car with normal maintenance, and those tires do not qualify. you will need to replace them anyhow.
Exactly. You're basically risking your safety for nothing.
That's just... scary. Hit a bad spot in the road and BLAMMO!
Kind of defeats the purpose of a sports car (GT car if you wanna nit-pick ) if you have to crawl around because of your tires.
I'm not a Z owner (I just really enjoy your site) so I'm not as experienced with feathering, but that looks more like the result of negative camber or toe in, which may be within factory specs.
Old Apr 22, 2005 | 12:56 AM
Z BOY's Avatar
Z BOY
yep, you would never have made it to 37k if you had feathering/tire roar cuz of the noise. Doesn't look like you had it...just good ol -camber.
Old Apr 22, 2005 | 04:15 AM
pfizzle's Avatar
pfizzle
how can you live with the vibration, my tires looked like that at 20k miles
Old Apr 22, 2005 | 05:22 AM
King Tut's Avatar
King Tut
Originally Posted by zand02max
Dude, what in the hell, thats is Tire feathering like a ****!
I am really getting pissed off now. THAT IS NOT FEATHERING. THAT IS INNER TIRE WEAR THAT HAPPENED OVER 39,000 MILES DUE TO THE CAR HAVING NEGATIVE CAMBER SETTINGS. That is perfectly normal and to be expected. If you don't like it sell the car or get a camber kit and set the car to 0 camber.
Old Apr 22, 2005 | 05:24 AM
King Tut's Avatar
King Tut
Originally Posted by Eddie1979
Hah thats awesome, normally i don't bicth about feathering but send those pics to Nissan!! I guess they will tell you 40k miles is plenty for a set of tires.
Another guy that has no idea what is going on. That is not Nissan's fault.
Old Apr 22, 2005 | 05:25 AM
King Tut's Avatar
King Tut
Originally Posted by bobS
Thats what my feathering looked like but i didn't let it get that extreme. Thats dangerous.
Another guy that doesn't know what feathering looks like. You can't even see the tread blocks on those front tires anymore to see if there was ever feathering.
Old Apr 22, 2005 | 05:26 AM
King Tut's Avatar
King Tut
Originally Posted by phile
Save those tires and send them to the dudes witht he law suit. Maybe they'll reimburse you for giving them evidence :P :P
The intelligence abounds in this thread. What evidence is that? Show me where Nissan promised that you will get even tire wear for 40,000 miles.
Old Apr 22, 2005 | 05:27 AM
King Tut's Avatar
King Tut
Originally Posted by Fiction520
I think any tire with 40k miles and any negative camber is going to look like that. It's not a case of feathering or premature tire wear. It's normal tire wear.
I am glad that a few people posting in this thread know what is going on. That is a very intelligent response.
Old Apr 22, 2005 | 05:47 AM
zzz350's Avatar
zzz350
stupid is, as stupid does!
Old Apr 22, 2005 | 06:14 AM
Netko350Z's Avatar
Netko350Z
Originally Posted by formulaZ
wearing just on the inside portion of the tires can be linked not only to feathering. looks like normal wear with a setting of negative camber. my guess its roughly -1 to -1.3....
+1 BUT THAT ISN'T FEATHERING!!!! Feathering is where the tred pattern wears in such a way that each individual tread wears in such a way that there is a high spot at one side and a low spot on the other side. When you run your hand over the tread you can feel the high sports in one direction but not in the other direction.
Tire Wear Guide
The following Tire Wear Guide will help you identify the causes and solutions of most common tire wear patterns.
Wear PatternCauseSolutionCenter Wear
Over Inflation
Adjust pressure to particular load per tire catalogEdge Wear
Under Inflation
Adjust pressure to particular load per tire catalogSide Wear
Loss of camber or overloading
Make sure load doesn't exceed axle rating. Correction is 3/4 - 1 degree positive camber (top of wheel rim 3/16" further out than bottom.Toe Wear
Incorrect toe-in
Correct toe-in is 0 - 1/2 degree.Cupping
Out-of-balance
Check bearing adjustment and balance tires.Flat Spots
Wheel lockup & tire skidding
Avoid sudden stops when possible and adjust brakes.
Old Apr 22, 2005 | 06:36 AM
phile's Avatar
phile
Do you work for Nissan or something? If you notice the two smiley faces, it was a joke you stupid ****. He who is so concerned about the intelligence of others, must have a deficit of intelligence himself.
By the way, for an intelligent person such as yourself, i'm surprised you used the intransitive verb "abound" improperly in your first sentence. Lets see if you are "intelligent" enough to make the slight corrections.
Old Apr 22, 2005 | 07:16 AM
mpol99's Avatar
mpol99
LOL, yeah that is NOT feathering. That is negative camber, as a few members have already pointed out! NORMAL for a car that has negative camber settings STOCK (for handling purposes).
My rears looked like your fronts at about 17K miles
Old Apr 22, 2005 | 08:03 AM
King Tut's Avatar
King Tut
You think I was questioning your general intelligence? I don't know you. I have no idea how intelligent you are. I was saying the intelligence of tires and feathering was lacking in this thread, and your post definitely wasn't helping.
Old Apr 22, 2005 | 08:40 AM
boma's Avatar
boma
This was feathering about 5k ago. As I was taking pics just now to show the feathering, it now looks like this...............
What tires could I buy that will help prevent this kind of wear again? Cheap ones too.
Attached Thumbnails 39778 Miles + Stock tires =.......-image-026-.jpg   39778 Miles + Stock tires =.......-image-027-.jpg   39778 Miles + Stock tires =.......-image-028-.jpg   39778 Miles + Stock tires =.......-image-029-.jpg   39778 Miles + Stock tires =.......-image-030-.jpg
Old Apr 22, 2005 | 09:29 AM
King Tut's Avatar
King Tut
You can't buy any tires to prevent the insides from wearing out quicker than the outsides. That will inharanely happen with the 350Z due to the negative camber our cars are setup for. Those tires look fairly evenly worn in the pictures. The cheaper you go with tires generally the less tread life you willl get.
Old Apr 22, 2005 | 09:45 AM
Asterix's Avatar
Asterix
This is why I have no problems with Virginia's yearly safety inspection. The other cars on the road can get only so bad before somebody looks at them...
Asterix
Old Apr 22, 2005 | 09:55 AM
jmagilto's Avatar
jmagilto
Dude,
when you turn it back they will charge you for tires. why not spend the money now - on yourself. For your own safety!
jer
Old Apr 22, 2005 | 10:02 AM
  #38
engiNERD350Z's Avatar
engiNERD350Z
Since most are thinking it, I'll just say it. YOU ARE AN IDIOT.
Want a professional opinion to cross reference? I'm an engineer. YOU ARE AN IDIOT. That's why we design with safety factors, or as we like to call the "idiot factor" because of people like you.
Old Apr 22, 2005 | 12:45 PM
  #39
nitrousoxidex's Avatar
nitrousoxidex
to thread starter-
im guessing youre cantonese? gillian is pretty lookin i gotta say.
Old Apr 22, 2005 | 12:54 PM
  #40
PerfZ's Avatar
PerfZ
And why would you lease and put that many miles on a car? all those miles are going to kill you when you turn it back in.
