License Plate Problem - HELP!
Old Nov 23, 2002 | 07:27 PM
mcduck's Avatar
mcduck
Default License Plate Problem - HELP!
Received my real tag (to replace 30 day tag) in the mail today.
When I swapped them out, the mounting screws would not seat all the way leaving the license place loose. Tried taking the plate back off and one of the screws will not come out!
I'm so pissed I can't see straight! I've done everything I can think of, including bending my new plate so I could get to the little access hole next to the faulty screw. As close as I can figure the mounting bracket is stripped. The screw will neither go in further or come back out. It will turn either way, but a noticeable "notch" type feel can be felt while turning and occurs 3 or 4 times per full rotation of the screw.
Any ideas on how I can get the plate back off so I can replace the mounting brackets and mount the plate properly?
Old Nov 23, 2002 | 07:46 PM
Old Skooler's Avatar
Old Skooler
Only thing I can think of is to take a small flathead screwdriver and put it behind the head of the screw and use it as a lever to apply pressure towards you, while turning the screw with another screwdriver to remove it. Don't apply too much pressure, but enough to help it "catch" the threads and hopefully it'll come out.
Old Nov 23, 2002 | 09:13 PM
Subw00er's Avatar
Subw00er
get a pair of vice grips and pull like hell while turning counterclockwise. If you are talking aboutthe front plate, there are metal slipnut things that can be easily replaced - ok if yours are shot.
Old Nov 23, 2002 | 09:15 PM
mcduck's Avatar
mcduck
Thanks for the tip, Matt... already tried that, tho. I've run out of reasonable options. Probably will take it to the dealer this week to see what they can do. Who would of thought you'd need a Nissan tech to change a license plate...
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
