K&N Air Filter test
Old May 11, 2005 | 04:54 PM
311roadster's Avatar
311roadster
Default K&N Air Filter test
Take a look and let me know what you think?
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Old May 11, 2005 | 05:05 PM
zand02max's Avatar
zand02max
Someone care to break this down in 10 words or less?
I am assuming the K&N did well or it did terrible and just another marketing scheme to pay more for less!
Old May 11, 2005 | 05:47 PM
slowxturtle's Avatar
slowxturtle
again, i'm gonna have to ask, what about JWT popcharger?
Old May 11, 2005 | 07:15 PM
Netko350Z's Avatar
Netko350Z
yea any cliff notes?
Old May 11, 2005 | 08:01 PM
Hogstar's Avatar
Hogstar
Read the last two paragraphs.
Old May 11, 2005 | 08:05 PM
Z BOY's Avatar
Z BOY
sum it up for us.
Old May 11, 2005 | 08:35 PM
Hogstar's Avatar
Hogstar
" The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give. And this remains true until the filter is dirty enough to trip the air filter life indicator. At that point performance will decline somewhat. Replace the filter and get on with it. "
Old May 11, 2005 | 08:42 PM
Z BOY's Avatar
Z BOY
okay, but what about the flow of k&n vs stock?
what the "engine has to give" is something we are trying to change via mods. was the test done on a stock engine? sorry for being too lazy to read the article, and thanx for the thread.
ps: what's a filter-life indicator?
Old May 11, 2005 | 08:51 PM
Hogstar's Avatar
Hogstar
It was done on a flow test machine. Very sophisticated.
P.S. ??? I guess some cars have a way of checking air flow changes I don't think the Z does this.
Old May 16, 2005 | 08:20 PM
Z BOY's Avatar
Z BOY
finally got around to reading the test. The K&N was poorest at particulate filtering, but we hp guys aren't concerned about filtering. We want max air flow, and the k&n was the best at doing that in the test, which means if we use hiflow air filters, we need to change oil more often and use high filtration oil filter to prolong the life of our engines.
ps: look at the "resistance to flow" graph at the bottom. k&n had the least resistance to flow of all the filters tested.
Old May 16, 2005 | 08:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1, the article even admits that it may make a difference if your car / truck is heavily modded:
Originally Posted by (from article)
However, if a filter is using "better airflow" as their marketing tool, remember this....Does it flow better? At very high airflow volumes, probably. BUT, Our trucks CAN'T flow that much air unless super-modified, so what is the point? The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give.
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
