Problem with Tire Pressure monitoring....
on
Has anyone else had this problem? I get into my car today and drive about 50 feet, then a buzzer sounds and my Tire Pressure Monitoring System light comes on on the dash. I check my gauge and it says that I have 29psi in all my tires. I figure it will go off when the tires warm up and the psi increases to around 32. Well, after about 20-25 minutes of driving my gauge says that I have 33psi in all tires - but the Monitoring System light never went out on the dash and "psi" was flashing in the lower right hand corner of my gauge. After I got to work, I tried turning off the car and starting it again to see if the light would go out - it came back on again. How do I get the light to go out on the dash? Has anyone else had this happen to them?
one tire must have dipped below 28psi to trigger the alarm. Once triggered, you have to get all 4 tires to read 35 or above and it will reset automatically. Recomended is 35psi cold, some run 32-33psi for a slightly softer ride; either way, this will provide a reading of 35 or higher when warm. Your car is trying to tell you something; you are running your tires a little low.
08-06-2021 06:19 AM
