Wobbling idler pulley
Old Jun 19, 2005 | 04:04 PM
tware's Avatar
tware
Default Wobbling idler pulley
I've got a cold start screeching noise and so far two dealer visits havent addressed it (new belts and now a new AC compressor). So I changed my oil and while running the car without the lower cover (doing the leak check thing), I noticed the driver side pulley wobbling like mad. From the top, its clearly visible, but when seen from the bottom, you can really see alot of movement in the belt. You can see it better because you can see the belt coming from the compressor and over to the crank, just easier to see the full scope of the wobble. I cant believe two dealers didnt notice this, but I've been living with it for at least 8K or more. Perhaps closer to 10k.
It was hard to diagnose because once the car is warm, it doesnt make a peep. But clearly it just had to be looked at.. Instead of leaving my car overnight repeatedly for a cold soak start. :/
Ok, to my question... Does anyone think that a seriously wobbly pulley for 10K will have reprocussion for the crank? I just got a new AC compressor, so I'm not worried about it... but I dont know if the vibration would have an effect on the seals or bearings on the lower end.
This kills me because every Nissan I've owned has had bad idler pulleys within 30-40K. Yet every dealer I've talked to acts like they've never replaced one (even when my Pathfinder had a TSB for it)
Old Jun 20, 2005 | 12:39 AM
vincei's Avatar
vincei
I have the same problem, dealer said it was fixed but came back the next day. I am bringing it back this week to get my axles replaced so I'll mention the idler. It's a really embarrassing noise!! Sounds like a beater!!
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
