Max WHP
if you want to do it ship it to Charles.
www.cj-motorsports.com
if you got the $ he has got the know how, tuning experience, to get it there.
7800- AEBS stroker kit
6000-8000 for APS or up coming JWT turbo kit
3000 -4000 total install
then with the remainig 8-11 grand , clutch, wheels, coilovers and swar bars, ih and domt forget the nismo themostat and stillen oile cooler and torque dampener, Thats approsimately 30 grand, maybe a little more but not much.
Originally Posted by sentry65
here's a rough breakdown:
$8000 greddy kit and all the needed extras the kit doesn't come with
$3500-5000 standalone EMS
$12000 buil up block, new cams, ported heads, heavy duty valves/springs, sleeves, etc
$4000 wider tires/wheels
$1200-2000 LSD
$2000 carbon clutch
$2000 return fuel system and bigger injectors
$1000 misc cooling items, radiator, jethot coating
$1500 plenum, test pipes, exhaust
labor (being a little optimistic with these figures)
$2000 TT install
$2000 engine install/teardown
$1000 misc install
$2000 tax/shipping
= $42000-45000
of course that does not includes brakes, suspension, suspension control arms, vented hood, etc
if you want those things, you're probably looing at an additional $10,000
$1200-2000 LSD
$2000 carbon clutch
$2000 TT install
$1000 misc install
$2000 tax/shipping
= $42000-45000
8k for greddy TT...are you nuts?? you can get those for like 4-6 anywhere now..
1500? for plenum exhaust and test pipes...lets see...borla td 700..helix pipes..150..plenum/spacer 220-400
building an engine is around 10k...he can do...where tha hell do you get these #'s from man..i know these are correct cause my friend is building his as I type..injectors that come with the greddy should be good for 500-600whp..
wider tires and wheels??? 4k??? he can throw some drags on his rears if he goes to the track...gforce should hold up on the street..
your way off with these #'s...
edit: http://www.intensepower.com/grcotwtukitw.html
greddy tt shipped 5800
Originally Posted by taurran
I'd have to agree here. I don't think this would cost you any more than 30k. A big factor would be weather you can do the install work yourself or not.
Originally Posted by 350z4steve
Nice Budget..sure you can do it the TT is rought only 8K-12K installed unless you do it yourself and the rest can be spent on the lower end goodies not to mention a good tune.
i can spent more than $30k... I was just wondering.. My parents are trying to see how much they need to put in my bank account for me. I could probably try to get $50K. Not quite sure yet. I haven't told you guys that i'm only 17 yrs. old.
GReddy TT kit with GReddy FMIC - $5,400 (PM me for where to get this price)
Electromotive Tec3r Engine Management with Electromotive 3 bar MAP sensor, coolant sensor, MAT sensor, throttle position sensor, DFU (for 6 cylinder), and XDI direct ignition system - ~$2700
Walbro 255lph In-tank fuel pump - $95 shipped
Return fuel system (preferrably mine
) - $1000
Gauges - ~$500-600
Air Power Systems (APS) test pipes (extreme performance (3.5")) - ~$200
Borla true-dual exhaust ($699) or Air Power Systems (APS) extreme performance true-dual exhaust (~$1200)
RC Engineering 650cc fuel injectors ($580 shipped)
ARP head and main studs - $366 shipped
Pauter connecting rods - $1,170 shipped
Arias extreme duty pistons - $1,050 shipped
NGK Iridium spark plugs - $65 shipped
ATS twin plate clutch with flywheel - $1,990 shipped
Driveshaft Shop Level 5 half-axle - $1,549 shipped
Quaife LSD - ~$1,300
Darton M.I.D. sleeves - $1,050
Wilwood big brake kit - $3,590 shipped
KJR Performance crank pulley - $170 shipped
Tein basic coilovers - $800
Stillen oil cooler - $355
GReddy oil catch tank - $91
Tomei 268 cams - $1,179
Ferrea valvetrain - $1485
Koyo radiator - $468
Hotchkis sway bars - $324
Stillen rear camber adjuster - $439
B&M short shifter - $169
Agency clutch line - $49
APS oil pan - $455
Crawford cast plenum - $450
= ~$30,000
You'll also want to get some wider rims for wider tires.
That will put you at 600 reliable rwhp though.
Hope this helps.
BTW, I would recommend getting the work done (whatever work you won't be doing on your own) at SGP Racing. They have not blown ONE VQ35DE in a 350Z or G35 and they have done tons of engine build-ups and turbo installations and supercharger installations. That speaks VOLUMES about how good they are.
Gauges - ~$500-600
APS oil pan - $455
= ~$30,000
Hope this helps.
I have read through almost every 350Z website for the past 2 years without posting so I learn everything I can. I would probably research all other websites out there also to get a grasp on what needs to be done with your car. At 17YRSOLD with a 600HP car is pretty much going to be a handful to race/drag for somone with limited experience. There are about 5 guys in this website that know what there talking about without BS'ing. I have saw NIS350ZTT on almost every forum and seems one of the most knowledgable. Take his advice.
Originally Posted by nis350ztt
I would edit that, you are going to get a TON of crap for saying your age. Just a forewarning. These guys will rip into you.
) - $1000
Gauges - ~$500-600
APS oil pan - $455
= ~$30,000
Hope this helps.
Gauges - ~$500-600
APS oil pan - $455
= ~$30,000
Hope this helps.
THANK YOU.. my real budget is $30-50K
why does my age matter what i drive or how much money i will spend our how much my parents are giving me?? Does that really matter that i am spoiled?? i don't care... I just want to go to school, then modify my car. My dad says it's ok to have a fast car, because when he was young.. he drove a 1985 Porsche 911 carrera coupe which he got from his dad for his 17th b-day. So thats why i'm trying to build up a fast car. It does not really matter how old i am
Originally Posted by Jason@Performance
RB26DETT / Custom Drive Shaft...
Call it a day
Call it a day
RB you can get more then 700 on stock internals...
in japan the HP motors produce is very limited....
that engine only produces 280HP.... my stock VQ35DE produces 300HP..35th anniversary edition
and just a piece of advice...take it or leave it it's up to you. "A little humbleness goes a long way." This applies everywhere...soon you will learn. It will come with age (hopefully).
