110 octane, is it safe?
Old Jul 7, 2005 | 02:46 PM
Zlayer's Avatar
Zlayer
Default 110 octane, is it safe?
Theres a gas station near me that sells 110 octane race gas, but it says that its leaded. I like the idea of putin in some high octane as a suplement every once in a while, but since its leaded Im guessin I should definately not put it in my car. And even if it was unleaded gas, would the ECU detect the high octane and not like it? I think its like $3.50/gallon.
Old Jul 7, 2005 | 02:50 PM
DG39's Avatar
DG39
Stay away from it. I doubt the computer could handle the octane. But I am not sure. Also I think lead additave in todays engines is not a good thing.
Old Jul 7, 2005 | 03:09 PM
n8vz's Avatar
n8vz
waste of money. The stock ECU can not adjust much past 94 Octane (MON+RON/2)
Old Jul 7, 2005 | 03:14 PM
sentry65's Avatar
sentry65
the burninator
don't buy leaded gas for the Z
Old Jul 7, 2005 | 03:17 PM
Vertex350's Avatar
Vertex350
Don't risk it man.
Old Jul 7, 2005 | 03:21 PM
XV8DRVR's Avatar
XV8DRVR
Leaded gas plus O2 sensors = BAD
Leaded gas plus cats = BAD
Old Jul 7, 2005 | 04:15 PM
Zlayer's Avatar
Zlayer
Thats what I thought, thanx guys!
Old Jul 7, 2005 | 04:33 PM
AdrenalineFX51's Avatar
AdrenalineFX51
Just poor some in a cup to take it home and take a whiff of it every now and then. Ahhh, the smell of gasoline.
Old Jul 7, 2005 | 05:14 PM
rockinbboy's Avatar
rockinbboy
why would you even want to waste your money? Its not like you will get 300 HP or something from it. Even if you gained some HP, it will go to 0 when your engine breaks.
Old Jul 7, 2005 | 06:08 PM
spacemn_spiff's Avatar
spacemn_spiff
ECU probably cannot handle this gas because it might not be able to retard the timing to get proper combustion. You might lose power because of that. You will need engines with higher compression ratio and higher rpms to use it.
Lead is a big NO.
Old Jul 7, 2005 | 07:20 PM
maxipad96's Avatar
maxipad96
Just for ***** and gigles I put this in my old car. It really did nothing for performance. Eventually I began to burn oil really bad though. Don't know if this was related or not.
bcoffee20
Nov 19, 2015 06:39 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
FromGtoZ
Sep 20, 2015 03:41 PM
