Possible Hidden Rust Spot in the making
Old Jul 19, 2005 | 12:46 AM
MrGraphics's Avatar
MrGraphics
Default Possible Hidden Rust Spot in the making
I bought my 7443 chrome bulbs from www.autolumination.com (great service BTW - great product - pic included) and after I removed my tail light housing, I found this spot on each side with all the paint rubbed off. It would only be a matter of time before this was bare metal.
We Cali people aren't that worried, but the rust belt people . . . this is a disaster waiting to happen. Once you get a rust bubble here, its all over.
I cleaned up the spot, applied touch-up and a clear coat layer, then glued some thin rubber there to act as a buffer. I also waxed the entire area behind the tail lights for extra protection.
Removing the taillights takes 5 minutes . . . probably worth it to make sure you're ok.
To remove the tailights, pop out the 3 plugs on top of them, unbolt, and with some force, pull up from the corner closest to the bumper. They will pop out with some finesse.
Attached Thumbnails Possible Hidden Rust Spot in the making-pict0505.jpg   Possible Hidden Rust Spot in the making-pict0507.jpg
Old Jul 19, 2005 | 09:48 AM
the7ferret's Avatar
the7ferret
wouldn't worry too much the rear facia is plastic.
Old Jul 19, 2005 | 10:28 AM
MrGraphics's Avatar
MrGraphics
umm . . . rear bumper yes, body panel no. That is the upper part of the taillight (where it comes to a point.)
Look at my avitar. See my antenna - see where the taillight ends half way up the hatch? That's metal there -
Old Jul 19, 2005 | 11:33 AM
bluRS's Avatar
bluRS
I have the same problem too, I thought it was from me getting rear ended a while ago though
Old Jul 19, 2005 | 12:08 PM
the7ferret's Avatar
the7ferret
ohh I couldn't tell so I thought it was the area in the second pic.
n/m your right.
Old Jul 19, 2005 | 12:27 PM
Edison_Chen's Avatar
Edison_Chen
I also have rust in the hatch area....
Old Jul 19, 2005 | 05:51 PM
engiNERD350Z's Avatar
engiNERD350Z
It's actually been posted before a year ago and was happening to others, but thanks for the heads up.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
