Question about Simple Rotation. (PIC Explanation)
Old Jul 27, 2005 | 05:54 AM
SangWL's Avatar
SangWL
Default Question about Simple Rotation. (PIC Explanation)
ok guys, i'm mad bored at work right now and obviously you can see, i have this simple question that needs an anwser.
as you can see, what i'm wondering is................
with the camber i have right now, can i just rotate the front tires with each other so that the inner wear is now going to be outside? Same with the rears.
I'm figuring i can't rotate the fronts from rear and rears from the fronts and what not, but it makes sense that i can just switch the tires from the fronts and also with the rears.
Am i missing something?
sang
Attached Thumbnails Question about Simple Rotation. (PIC Explanation)-camber.gif
Old Jul 27, 2005 | 06:31 AM
spacemn_spiff's Avatar
spacemn_spiff
Since the tires are staggered and unidirectional, you need to mount and balance the tires again when you want to rotate them. So front will go on fronts and rears on rears.
Nice avatar of Calvin, Calvin and Hobbes rules.
Old Jul 27, 2005 | 07:48 AM
SangWL's Avatar
SangWL
yeh thats what i figured, i knew i would have to dismount them and then switch them.
has anyone else done this?
i'm guessing i could save at least 10000 more miles
sang
Old Jul 27, 2005 | 09:51 AM
King Tut's Avatar
King Tut
Yes, plenty of people have done that. You need to swap the tires around on the wheel and then swap the sides to maintain the directionalness properly.
Old Jul 27, 2005 | 10:29 AM
SangWL's Avatar
SangWL
yeh just called my techy guy.
thanks guys
sang
Old Jul 27, 2005 | 02:33 PM
mrgqpnoi's Avatar
mrgqpnoi
quick question:
i know its probably in the manual but i haven't bothered to check and maybe i can get answers from the "real" experts. how often should we mount/dismount our tires? I have an 04.5 and nearly approaching 10K miles...
Thanks!
-aL
Old Jul 27, 2005 | 02:48 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by mrgqpnoi
quick question:
Thanks!
-aL
I would say never, as long as you keep your tire pressure within specs, your alignment is maintained, and you do not see any unusual tread wear. You can't rotate fronts to rears anyway because of the size difference.
Old Jul 27, 2005 | 03:17 PM
Kevin3's Avatar
Kevin3
I've switched the fronts with each other. It did drive a little smoother, but the noad noise increased! I even switched the fronts to rear, and rear to fronts to see if it made a difference. The car drove great for a thousand miles or so, but then started getting really loud again. Ended up buying new tires b/c noise and rough ride was unbearable.
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
Tochigi_236
Sep 27, 2015 03:40 PM
