need stock gps
Guest
Posts: n/a
can you order the nissan nav if you decide later that you want it? and if so how much does it cost? if the answer is no what if I said I broke my original then could I get one?
so many questions so little time (actualy bought mine in late oct. so I guess I have alot of time since delivery is in late feb.)
From what I understand, you cannot add the nav system. The car MUST be ordered and built with it. There appears to be several differences in wiring that is ONLY put in whenthe car is being built. If you wanted a replacement you would pay and arm and a a leg.. plus you would have to purchase all the needed cableing which would be almost impossable to install on a car that is already built..
Good Luck...
Steve (k2we) Dobbs Ferry, NY
Good Luck...
Nope. Apparently it can't be added later. It's wired all over the car and hooked into the ECM as well. If you really want it, see if your dealer can add it to your order if it's not too late. Only other option is to go aftermarket.
