350Z Oil change!!
Old Aug 15, 2005 | 01:41 PM
AvengerZ's Avatar
AvengerZ
Cool 350Z Oil change!!
Does anyone know what kind of LSD oil our cars use? also the manual transmission oil as well.
How many choices of variaty do I have?
Any advice, suggestion would be appreciated.
Thanks.
Old Aug 15, 2005 | 01:42 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
i would suggest using Mobile 1 oil.
Old Aug 15, 2005 | 01:44 PM
AvengerZ's Avatar
AvengerZ
is there some sort of model numbers for it?
Old Aug 15, 2005 | 01:45 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
no. Just go to any walmart or costco, looking Mobile 1.
Old Aug 15, 2005 | 01:56 PM
ZZ33bOI's Avatar
ZZ33bOI
MObILE 1, just changed my oil the past weekend GOTTA usE mobile 1 full Syn.. car pures likE A sexy ***....
Old Aug 15, 2005 | 02:14 PM
AvengerZ's Avatar
AvengerZ
isnt LSD oil and transmission oil different from the engine oil?
Old Aug 15, 2005 | 02:41 PM
Tac-M's Avatar
Tac-M
Yes, but Mobil 1 makes a gear oil also. Here is a link, please correct me if I'm wrong but I think this should be good for the trany and the diff as well.
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Old Aug 15, 2005 | 03:42 PM
King Tut's Avatar
King Tut
I don't have the numbers but there is a specific viscosity rang our tranny and diff take and Nissan is the only company that makes the exact range, but other companies have ranges that are close. Check out redline and royal purple gear oils.
Old Aug 15, 2005 | 04:21 PM
MrGraphics's Avatar
MrGraphics
I wouldn't go synthetic in the car until after 10,000 miles. There are reports of those who started using synthetic right away, and not dinosaur first . . . their seals started leaking.
Old Aug 15, 2005 | 07:26 PM
arejohn's Avatar
arejohn
Anyone consider starting with the owner's manual. Viscosity not same for tran and rear. There is also a trany TSB that mentions Nissan p/n required for warranty work.
Old Aug 15, 2005 | 07:29 PM
zBoone05's Avatar
zBoone05
Good Advice MrGrapics,
The dealer/parts/body shop guys at my local Nissan dealer, who supposedly spend much time on mod stuff on the side said:
The synthetic is not good to use until after your first oil change, so between 4 -6K miles, you can start running a synthetic. He told me change out with normal oil at 1K and then synthetic at 4K.
As to the weight, my limited knowledge is that it depends on your region of the country, the weather/temperature etc. Short - climate.
Old Aug 15, 2005 | 07:32 PM
Vader007's Avatar
Vader007
The Royal Purple stuff is good too!
Old Aug 15, 2005 | 10:51 PM
mrZeee's Avatar
mrZeee
syn Mobil1 is not available in the weight spec'd for our rear diff
I believe the TSB is for auto trans not a manual
Old Aug 15, 2005 | 11:12 PM
AvengerZ's Avatar
AvengerZ
?_? whats goin on here... so what kind of oil should I get? >_<
Old Aug 16, 2005 | 05:34 AM
spacemn_spiff's Avatar
spacemn_spiff
I wouldnt get any other oil than what Nissan recommends. I have read on other forums that using other oils is not good for bushings etc.
Old Aug 16, 2005 | 08:41 AM
Z'd's Avatar
Z'd
Do a search on this in the "Repairing" forum. The posts here so far are doing no service to the question. A bunch of rumors and hearsay.
First of all, breakin in an engine and in gears (the 6MT or rear diff) are totally different. Second, synthetic is not going to cause your seals to leak- maybe on an old car that has 150K miles and always ran the cheap stuff, but not on a new Z. I have been running full synthetic in the engine, 6MT and rear diff since 2500 miles and the performance is much better- especially the shifting.
There is a different API Service classification for the 6MT and the rear diff- one is GL-4 and one is GL-5, if memory serves correctly. You can buy a synthetic Amsoil product for each application (and the engine, as well). This is what I run. There are other options as well. You do NOT have to use Nissan fluids to keep your warranty intact.
JjL
East Canada
Jun 12, 2019 03:04 AM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
SonnyWu
Nov 24, 2015 08:19 PM
bcoffee20
Nov 19, 2015 06:39 PM
rizzla
Drag
Sep 17, 2015 08:44 AM
