clutch
Old Sep 13, 2005 | 01:51 PM
Escobar's Avatar
Escobar
Question clutch
lets say your sitting at a stoplight for a minute and you hold the clutch down, will this cause it to wear quicker than disengageing it?
Old Sep 13, 2005 | 03:18 PM
DavesZ#3's Avatar
DavesZ#3
Yes, you're putting pressure on the throw-out bearing. Put it in neutral and let out the clutch. Besides that, your leg won't get tired from holding down the clutch, especially in heavy traffic.
Old Sep 13, 2005 | 06:51 PM
Escobar's Avatar
Escobar
yeah, it is easier to do let it out i was just wondering if it actually made a difference mechanically, thanks for the reply
Old Sep 13, 2005 | 08:13 PM
Z_Driver's Avatar
Z_Driver
Master
But, then you are wearing the input shaft bearing of the transmission. The way I see it is it's cheaper to replace the throw out bearing than take apart the tranny and install a input shaft bearing. If you aren't wearing one your wearing the other.
Actually, if you think about it you are disengaging and engaging the clutch twice if you puit it into neutral at a stoplight therefore more wear on the clutch disc itself.
The Z's clutch is quite light in stock form. However, in my Firebird the pressure plate has such a high holding pressure that I have to give my leg a break at the stoplights and throw it into neutral every so often.
my .02
Old Sep 14, 2005 | 11:30 PM
TeCKNeiC's Avatar
TeCKNeiC
Ive only been here for a few days but it seems like this question comes up 2 -3 times a week. I could be confusing myself since I use the search option so much.
Old Sep 14, 2005 | 11:48 PM
Chad68's Avatar
Chad68
I have never driven my cars that way.
Old Sep 15, 2005 | 03:14 PM
ws350's Avatar
ws350
I just happened to see this today:
http://www.washingtonpost.com/wp-dyn...062301111.html
He addresses this very issue on the seventh question.
I used to think the right thing to do was to leave it in neutral to reduce wear on the throwout bearing.
Old Sep 15, 2005 | 05:05 PM
nicolaycastro's Avatar
nicolaycastro
no matter what that guy says I cant imagine myself holding the clutch for that long... can you say pain.
Old Sep 15, 2005 | 08:48 PM
Z_Driver's Avatar
Z_Driver
Master
It like a leg press. You leg strength improves over time.
Old Sep 15, 2005 | 08:54 PM
Shift into neutral at a stoplight? Never tried it. If I’m waiting for a train to pass, I might put it in neutral.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
