parking in gear
Old Sep 20, 2005 | 05:41 PM
babbagandu's Avatar
babbagandu
my brake doesnt even work. the only thing keeping my car from rolling down my steep driveway is the gear.
Old Sep 20, 2005 | 05:44 PM
Dream350Z's Avatar
Dream350Z
Originally Posted by rockinbboy
wow..didn't know that. This a problem here in MD? I've been here almost 2 years and it gets cold..but not like NY cold. I'd think it would be safe to have the E brake.
Don't think that. I'm right above you in PA, I used to have an eclipse that the e-brake froze daily. I was always an idiot and forgot to not engage it, and every morning it would be frozen...took several miles of driving to get it unthawed. Needless to say, I went through a new set of rear brakes real quick two winters ago. It is especially worse if you're driving in snow and use it, the snow that is clumped up underneath the car freezes to the e-brake cable
Old Sep 20, 2005 | 06:50 PM
yeperra's Avatar
yeperra
I almost never use the parking brake. I just leave it in 1st.
Old Sep 20, 2005 | 08:46 PM
The Mike's Avatar
The Mike
Originally Posted by tabrizio
Why not just put it in gear to be safe?
The truth is because i'm not used to it. I've had a couple of incidents where i start my car and lunge forth. Not very fun. Quick question... does the e-brake engage the left rear, right rear, or both at the same time?
Old Sep 20, 2005 | 10:30 PM
marine in a Z's Avatar
marine in a Z
i leave mine in neutral. my eclipse had a turbo timer so i had to leave it in nuetral. i bought this car and started leaving it in gear but almost hit my dads pos like 2 inches in front of me. i also had it jump on me a couple time becauase i forgot. so i just choose to leave it in nuetral now.
Old Sep 21, 2005 | 12:33 AM
TeCKNeiC's Avatar
TeCKNeiC
Anyone in here start the car in gear or does everyone start in neutral?
Old Sep 21, 2005 | 12:41 AM
Z_Driver's Avatar
Z_Driver
Master
I park my car in 1st or reverse. I use my parking brake as back up on any grade. I turn my wheels into the curb on downhills and away on uphills with the car in gear with parking brake on. If I find my Z in freezing weather I make sure I park on a level street without the e-brake engaged and block the wheel if I have to park on a grade.
Old Sep 21, 2005 | 12:47 AM
Since you have to push in the clutch to start the car, the position of the shifter doesn't matter to me.
Old Sep 21, 2005 | 05:02 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by davidv
and to add...
Downhill: the front wheels are turned into the curb.
Uphill: the front wheels are turned away from the curb.
Temperature below freezing:emergency brake OFF.
I dont ever turn my wheels, I dont want my LE37's getting lips scratched against the curb if the car does roll. I too always leave it in gear, and in my other car a Probe, I never use the ebrake cuz they stick all the time in those cars, even in the summer.
Old Sep 21, 2005 | 07:06 AM
thief's Avatar
thief
so when you guys turn off your car, your foot is on the clutch(so it doesnt stall) and in 1st gear?
Old Sep 21, 2005 | 07:37 AM
elms350Z's Avatar
elms350Z
Always in 1st, unless you have a remote starter.....I want one of those for cold mornings especially when you're running late for work. That can save you up to 2 minutes of warm up time.
Old Sep 21, 2005 | 09:34 AM
highside107's Avatar
highside107
Originally Posted by harrieyu
when parking always put the parking brake on first and then after the car rolls the inch or two that it always does, then apply the gear accordingly. dont want to put unnecessary stress on the gears.
+1 This is exactly what should be done. The stress should be put on the e-brake *only* if possible, not on the tranny. As people above have stated, leaving the car in gear is just in case the e-brake fails.
Old Sep 21, 2005 | 11:16 AM
yeperra's Avatar
yeperra
The stress induced by leaving it in gear even on a hill is nothing compaired to driving even on level roads. What do you think is happening when 287 or 300 hp is being applied?
By pushing the clutch in to start the car the transmission is disengaged so it shouldn't matter what gear it's in.
Old Sep 21, 2005 | 03:42 PM
The Mike's Avatar
The Mike
You can shift your car all day/night long once your car is off. It's been a while since i played with it but I think you don't even have to use your clutch when the car is off.
Old Sep 21, 2005 | 04:08 PM
Aced16's Avatar
Aced16
well i might get chewed out for this but... I DONT LEAVE MINE IN GEAR! ok let me explain, i live in south Fla, not many hills, and cant leave it in gear with the remote start, would launch foward and that definately wouldnt look cool huh? LOL
Old Sep 25, 2005 | 06:00 PM
Zeero's Avatar
Zeero
Originally Posted by vo7848
Yeow! What a bunch of 350 Zcars!
Never mind the emergency brake, how can we participate in this gathering of Z cars?! I assume you have a good time swapping stories.
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
