Tire PSI
Old Sep 22, 2005 | 07:30 AM
kt350z's Avatar
kt350z
Default Tire PSI
What does everyone usually run in thier stock tires cold ?
Currently I run about 33 cold which gives me about 36 hot
Would be interested to see what the average is
Old Sep 22, 2005 | 07:42 AM
Vamos_Rafael's Avatar
Vamos_Rafael
41-43 atm
thats after auto-x and i didnt let tire pressure out
auto-x was like 47ish hot lol
Old Sep 22, 2005 | 07:49 AM
35 psi cold
Old Sep 22, 2005 | 08:13 AM
Vamos_Rafael
more psi = better gas milage?
Old Sep 22, 2005 | 08:20 AM
drifter23's Avatar
drifter23
I keep mine at 36 psi when tires are cold. I believe the tire pressure for stock 17's should not be inflated over 40 psi...correct me if I am wrong.(that is what is stated on the tire side wall.
Old Sep 22, 2005 | 08:24 AM
King Tut's Avatar
King Tut
In general yes as that will mean that less of the outside of the tread blocks is touching the ground. That means less tire contact patch and less friction but also less traction which is where the trade off comes in.
Old Sep 22, 2005 | 08:26 AM
The Brickyard Rat's Avatar
The Brickyard Rat
For 18s, recommended is 35 (cold) which is what I run.
Old Sep 22, 2005 | 09:11 AM
SkiTTlez's Avatar
SkiTTlez
+1
Old Sep 22, 2005 | 11:22 AM
kt350z's Avatar
kt350z
I am going to 35 cold
Thanks for the input
Old Sep 22, 2005 | 01:37 PM
The Mike's Avatar
The Mike
Yup, what he said... which also basically means you're tire is "rounded" in the middle so your middle tread gets worn but your outside tread doesn't... causes uneven tread wear in the long term if you always keep it like this. Hmm, with the Z's negative camber tho... guess you'd still get half a tire's worth of wear being from the inside edge all the way to the middle. Just a thought.
Old Sep 22, 2005 | 01:46 PM
harrieyu's Avatar
harrieyu
the reason gas mileage is better when there is more air is because the circumfrance of the tire is larger so it rotates less
Old Sep 22, 2005 | 02:04 PM
jwalshfam's Avatar
jwalshfam
I run 40oz cold, Mickeys.
Old Sep 22, 2005 | 02:40 PM
Swamibob's Avatar
Swamibob
The reason the gas mileage is better at higher tire pressure is because of less rolling resistance. The tire is harder and does not flex as much, thus it rolls easier.
Old Sep 23, 2005 | 07:34 PM
Zeero's Avatar
Zeero
Default Make it Easy
Just inflate your tires to 35psi (cold), and you will be fine. Ambient summer/fall temperatures where I live are above 90 degrees in August/September, and my tire pressure sensors show maximum pressures of 40psi after a few miles. That's good.
The biggest issue in the front tire feathering problem (other than mass hysteria) is that tire preasures are not kept correct. The low profile tires on the 350Z need to be checked AT LEAST once a week. If the pressure falls below 30 psi, you will have tire wear problems, even though your sensors don't give you a "low pressure" warning.
Driving a 350Z means never having to say you didn't pay attention.
Old Sep 23, 2005 | 10:21 PM
skip2daZ's Avatar
skip2daZ
what psi would i run on 20's?
Old Sep 23, 2005 | 10:30 PM
autois4pussies's Avatar
autois4pussies
Size doesnt matter. The car matters. When I went from 18-19 the psi didnt change. So on the Z I think no matter what size your using you need 35 cold.
Old Sep 24, 2005 | 05:28 AM
Kolia's Avatar
Kolia
+2
Pump up to near 40psi for track use.
Old Sep 24, 2005 | 07:40 AM
Fletch69z's Avatar
Fletch69z
I'm running 28 in the rears cold right now (dropped from 33 last night, haha) and about 30 in the fronts. I get really good traction though, . ANd my tires are already bald. Gotta get new ones after the winter so I like the traction.
Fletch69z's Avatar
Fletch69z
Oh, I bought it used so the tires were already getting there wear wise, I don't spin them very often. Plus I have 27K on the stock potenzas in the rear.
Old Sep 24, 2005 | 07:24 PM
engiNERD350Z's Avatar
engiNERD350Z
Not to start arguments, but this is wrong. There is neglible difference in the circumference of the tire with different pressures in relation to distance/rev. It's the contact area as mentioned previously, leading to less friction force applied to the tires by the ground, and hence, less force the engine has to overcome.
