Quick question on Tire PSI
Old Sep 29, 2005 | 06:52 AM
n3m3s1s's Avatar
n3m3s1s
Default Quick question on Tire PSI
I know this is a really elementary question, but what would you guys reccomend running the tires at. I looked on the tires and the max PSI is 51. I am wondering because on the way to work the warning came on for one of the rear tires being low. It was at about 28 PSI. I looked in the damn book everywhere and didnt see anything. If it helps I have the RE040 tires size 18". They are usually at 32-33 PSI for the botht the front and rear tires. To me that seems a little low, I was thinking maybe about 35-40 PSI. Thanks for the input on my lame question .
Old Sep 29, 2005 | 07:09 AM
ANXIOUZ's Avatar
ANXIOUZ
35psi cold.
Old Sep 29, 2005 | 09:03 AM
Z'd's Avatar
Z'd
I run 40. That way if it is cool in the morning they still register at 36. Plus, the stiffer tire and a non-Nissan alignment has eliminated my feathering.
Old Sep 29, 2005 | 09:06 AM
Fletch69z's Avatar
Fletch69z
I run about 28 in the rears right now (weather got a lot colder the last couple days) and my traction is great, . But I usually run low 30's. 32 0r 33.
Old Sep 29, 2005 | 09:35 AM
DavesZ#3's Avatar
DavesZ#3
The "damn" book (see section 9-9) and the sticker on the driver's door jam says 35 PSI.
BTW, under-inflation is the main cause of premature tire failure.
Old Sep 29, 2005 | 11:09 AM
The tire pressure is on the placard inside the drivers door: 35 psi.
Old Sep 29, 2005 | 11:28 AM
gsazabi's Avatar
gsazabi
I used to have exact same problem you had.
My TPM would go off every two weeks...whenever the weather got cold.
I bumped the psi to 35 and everything's fine now.
BTW,
If the TPM reads:
F : 35
_____
.....34
Does that mean my front wheel is 35psi and rear 34psi?
Or its saying on front wheel it's 35psi on the right tire and 34psi on the left?
This has been confusing me.
Old Sep 29, 2005 | 11:30 AM
Fletch69z's Avatar
Fletch69z
I think that the top one under F is left front and the bottom one is right front. Then when you change to the R setting it's the same thing just in the rear.
Old Sep 29, 2005 | 11:33 AM
n3m3s1s's Avatar
n3m3s1s
ok cool thanks guys. Didnt even think of looking on the damn door. Kinda lame they dont have it somewhere in the book.
Old Sep 29, 2005 | 11:39 AM
Fletch69z's Avatar
Fletch69z
Some Z's come with different tires I guess so VS. putting it in the books and having to print a bunch of different ones they just put it on the car, .
Old Sep 29, 2005 | 01:05 PM
jeeper78's Avatar
jeeper78
I thought every car has it on the car... same place you find out your paint code, GVWR, manufacture date, etc.
Old Sep 29, 2005 | 01:59 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
32-33psi is not even close to being underinflated. 35psi is suggested for street driving, but depending on the conditions you might want to run something different.
I need more air, mine are at about 32 and I can feel mushy sidewall flexing in the corners and stuff =\
Old Sep 29, 2005 | 02:11 PM
up2nogood's Avatar
up2nogood
I've always wondered the same. Which one is right/ left?!?!
can anyone co-sign for Fletch?
Old Sep 29, 2005 | 04:09 PM
DavesZ#3's Avatar
DavesZ#3
Apparently Nissan has not been consistant in the way that they're setup. Some people have left on top, others have right. The only way to tell for sure is to let the pressure out to about 30 psi in one then go drive it around and figure out from the display what yours is.
Old Sep 29, 2005 | 04:24 PM
Z'd's Avatar
Z'd
The placard that was put there by the same people that selected the tires and set them up so that they feathered and then refused to acknowledge the problem for several months??
Yeah, I'm real trusting of their advice on tires!!!!
Old Sep 29, 2005 | 07:06 PM
D350Z10's Avatar
D350Z10
35 psi for normal driving conditions, 22psi for drag racing, 25psi for course racing, 25-30psi for street racing. All for the oem tires!
Old Sep 29, 2005 | 07:35 PM
350ztoronto's Avatar
350ztoronto
great thread! =D
i was so wondering what my psi should be.. now to figure out left or right....
Old Sep 29, 2005 | 08:23 PM
gsazabi's Avatar
gsazabi
Mine's sat up like this when cold:
F : 35
_____
.....34
Does that mean my front tire air aren't even? 0.o
That's after dealer adjusted it for me too err...
Old Sep 29, 2005 | 08:38 PM
lax91181's Avatar
lax91181
I am fairly sure that like the gas gague, the tire pressure has an arrow that tells you which is which.
Looks like a triangle.
Old Sep 29, 2005 | 08:48 PM
n3m3s1s's Avatar
n3m3s1s
yeah I just went ahead and put them all at 35psi. It says to do it when cold but it was like 103 degrees when I did it lol!!
