When you shift gear, does your...
i do agree that you would have to ease off the gas when diengaging the clutch. But i feel that the RPm drop might be due to the 34lb flywheel that the Z's are equipped with. I geuss the the drop in RPM can be corrected with quicker more coordinated shifts.
Originally Posted by MeetJoeAsian
I'm not blaming the car...was just wondering if anyone else had the same experience....it is probably me though, I always try to shift gear as fast as possible before the RPM drops....so I pull off throttle as quick as possible and at the same time slam the clutch on and off as quick as possible...that's probably it there...
Yeah, you got it.
Originally Posted by mavtais
rpm will not drop the way you are concerned until you get on the clutch. if you cruise in gear and then take your foot off the gas pedal because you see a pedestrian up ahead running across the street (unless you're the type to speed up) your rpms don't drop. Like I said, pull off the throttle and wait before pushing the clutch. You will see that the rpms do not jump.
Yeah, you got it.
Yeah, you got it.
Because I had this problem too, I drive with my left foot resting on the kick plate, and both my hands at 10 and 2. Then when it comes time to shift, even though I try to move fast, as I take my right hand off the steering wheel my right foot comes off the throttle. As my fingers wrap the shift ****, I pick my left foot up from the kick plate and press the clutch, then shift. No jump in rpm. No kick in the pants and look like a rookie. Plus it feels more like driving on the track. How I long to go back to the Streets of Willow.... sigh...
ok..this may be a repost, but sorry, i didn't have the time to search the forum...but, when i shift my 6speed into gear, usually in the higher gears 3+, and shifting it fast and hard (as in pushing it into the gear), my RPM usually jumps a few hundred and then drops as soon as I release the clutch....sorry, I'm dumb...can someone explain?
I posted this when I first got my Z as that the effect of this is that it feels like it blips the throttle when I press the clutch to change the gear.
This happens to alot of people, just depending how significantly. Usually when you shift, you'll see the rpm bouncing up and down in between a few hundred rpms. It is normal. I had talked to a 350z tech regarding this situation the day i bought the car, thinking it was abnormal. He had explained to me because it was due to electronic sensors and not like other cars where they were not sent electronically, the rpm tends to be a little slow catching up.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
