Gearbox?
Hey what's up guys? I am getting a lot more used to driving the car around now. I haven't driven a manual in a while. I have a question though. Why is it that everytime I want to shift into 2nd, I have to muscle it through. It doesn't feel natural. This is like everytime. I mean is it because the car is fairly new and needs to get used to going into gates? Or should I worry that the gearbox is faulty? Any help is appreciated. Thanks in advance.
Same thing happen to my Z.
When I bought it new.......it was not getting into 2nd easily.......from first.
I thought because the car is new....but now I have 20k miles on my car...it's the same thing....it makes kinda grinding noise getting into second....especially engine is cold..I can hear the clattering noise....getting into 2nd.
I bring this up to Nissan dealer when I change oil... I'll keep you followup.
lol its the tranny sincros. Get ready for a fight with nissan about replacing your tranny. Mine is starting to be tough to get into second unless i let the car warm up for five minutes and i only have 6k miles on it. When the car is warm its great when its cold it feels like 2nd isnt even there sometimes.
You might want to try this. When you first start it cold. Let it idle in neutral with the clutch out for 10-15 secs. Then take off. You might also make sure you are not backing completely off the gas going from first to second gear. If you are going slow we sometimes do this. You should always have just a crack of thottle at least when going from first to second. This allow the syncros to line up better and keeps wear down as well. I know, I know that is what syncros are for. However, you might find much smoother shifts this way.
I can close the thottle between first and second I only feel like one or two syncro teeth as I go into second. If I use the method above I can't feel a thing and it goes in like butter.
Just my thoughts on the subject.
We'll the 350Z is known for a slightly knotchy 1-2nd shift. If it grinding hard of course they will fix it or, at least they should. I have heard of a few people that get grinds in 5th and Nissan tries to tell it's normal. This car doesn't grind, or shouldn't grind between gear changes. However, you still have to drive it like your supposed to or you will wear the syncros and it will eventually grind. You can mess up a tranny in six months or less if you don't know how to do it smoothly. Most people get it pretty darn close. You can actually up shift a manual tranmission if you know how to rev match without the use of the clutch. Downshifting without a clutch is much harder however.
I try to get 150K or more out of my tranmissions. I do this with proper driving, clutch adjustments as needed, fluid change in the system and clutch replacement sooner than later.
Man, I sure hope I don't have to deal with this...?
LOTS of people had problems with 2002 Nissan Sentra Spec V's and I didn't. (thank god)
My car feels really good except a very slight click every once in a while from the clutch.
My gears feel VERY smooth though. 05 Enth 6MT with 5K on the odo
I've never owned anything but MT though. About 13 cars now and counting...
My dealership here is pretty cool though if anything does come up
my tranny is hard to get in in ALL gears, but mostly 1-2. Damnit. Im afraid to take it to replace it, only to new problems. I am waiting till there is an actual grind before i take it in.
Also i tried replacing the tranny with royal purple fluid, and it help for like couple days...now its back to hard shifting again.
my original gearbox eventually grinded into 3rd, at 23k miles. My new tranny seems a bit more notchy, and 5th/6th are often kinda hard to shift into. Don't know why we can't just get a smooth, reliable tranny... was ours just a bad design or something from the beginning? I have driven many many cars and never had one with shifting issues. Yet Nissan can't/won't get ours right.
I think my tranny may be going too. Do you all have to feather the clutch while shifting or is that the usual. I find myself first dropping the clutch to the engagement point then easing off the clutch for all shifts before 4th. Does that cause more wear or should I look into a tran replacement?
Originally Posted by mc350z
have you guys noticed that 1st gear is exceptionally loud especially at high rpms?
Guest
Posts: n/a
Originally Posted by mecinoid
No no more than I would expect. 1st gear normally whines a bit more since it is the lowest gear. Not exceptionally loud however.
when you press the clutch in can you hear like a reverse whine sound like the the syncros or something slowing back down?
mine sounds weird but honestly ive only driven my Z so im not sure how normal it is
In 5th and 6th the guide should be 2-3mm off of the natural position in that gear.
Mine was wrong from the factory. Too large a gap 6mm or so. I found it during the short shifter install. Problem with that was the short shifter vibrated a lot. So, I switched it back adjusting the guide and now I don't really see any need to get a short shifter. It shifts smoothly and short enough for me. It is much easier to find 5th and 6th now.
Maybe the guide needs to be adjusted in your car. Pretty easy after you get the shift **** off.
Hard to say without hearing it and looking at the oil and levels etc...
