View Poll Results: Do you use your rear wiper?
Yes, its a must have, I use it often
14.29%
Only occasionally, but its important to have when needed
26
41.27%
I use it occasionally, but I could live without it for lower weight
12.70%
No, I never use it, take it out and make my car lighter
20
31.75%
Voters: 63. You may not vote on this poll
Rear Wiper or Lower Weight?
Old Oct 18, 2005 | 02:23 PM
EpicZ's Avatar
EpicZ
Default Rear Wiper or Lower Weight?
Are you using the rear wiper on your car? I never use mine and I'm wondering if I could remove it to save weight.
Old Oct 18, 2005 | 02:47 PM
bpr's Avatar
bpr
I used mine yesterday for the first time. I would not have been able to see to back out of my driveway if I hadn't had it. How much does it weigh, though, anyway? Even with the mechanism to operate it, it seems like it wouldn't be much more than a few pounds.
Old Oct 18, 2005 | 03:01 PM
sentry65's Avatar
sentry65
the burninator
i'm willing to find a rag/paper towel/kleenax/toilet paper/newspaper/whatever and wipe down the rear window should I need it where I can't see out of it at all
Old Oct 18, 2005 | 04:37 PM
gabez33's Avatar
gabez33
taking it off is not worth it in anyway, you wont see ANY benefit from it.....whats the phrase?? for every 100lbs is .1 sec off the time.....wiper weighs what...1-2 pounds...not worth it
Old Oct 18, 2005 | 04:41 PM
zYouLater's Avatar
zYouLater
Mine's out and it looks much better. Expecting muchhhhhh! better track time with weight loss..................LOL
Old Oct 18, 2005 | 04:48 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
its all about the clean look. the Z looks damn sexy w/o the wiper. the weight saving is just a bonus.
Old Oct 18, 2005 | 05:05 PM
Z_Driver's Avatar
Z_Driver
Master
Here is mine without the wiper, or wiper motor. I plugged and painted the plug with paint to match;
Old Oct 18, 2005 | 05:08 PM
need Z's Avatar
need Z
I think the Z looks great without it. But I use mine all the time... so it's still there.
Old Oct 18, 2005 | 06:23 PM
bmxox's Avatar
bmxox
If you put rainx on your rear window and drive more than 30mph, you will never need the rear wiper. Taking it off for wieght reduction though, the motor weighs like 2 pounds so it doesnt help out much in that area. Some people think it looks better without it, me included. Thats the only reason to take it off. And yes this topic has been talked about many times, and theres probably been 3 other posts about the rear wiper in the past week. Try searching.
Old Oct 18, 2005 | 06:50 PM
lunartick13's Avatar
lunartick13
Not even a week after I got my Z, I removed the rear wiper. I could not stand it i thought it took a lot of looks when you looked at the car from the rear. All I ever do after a car wash is apply some Rain x, never had a problem and the car looks IMO much cleaner without that ugly thing poking out the rear window + u loose a few lbs.
Old Oct 18, 2005 | 08:04 PM
tree phidday's Avatar
tree phidday
I live in Florida, 'n it is actually raining as I type this message. I use this wiper a hell lot. I wish I could take it off, but too bad I need it to back out of my driveway or from the school parking lot.....stupid rules and damn security that will ticket me if I back in park. Such a stupid rule...booo.
Old Oct 19, 2005 | 09:43 AM
lunartick13
wow!! GET THE HELL OUT OF THERE..
That really makes no sence at all.. Is that in case of a quick get away??? Ha,Ha
Old Oct 19, 2005 | 09:46 AM
Fletch69z's Avatar
Fletch69z
Where can you get a plug for the hole if you take off the wiper?
Old Oct 19, 2005 | 09:52 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Mines gone. You can get the plug @ Lowes or Home Depot. It's a sink hole plug, forgot the size. Under a buck.
Old Oct 19, 2005 | 09:56 AM
Fletch69z's Avatar
Fletch69z
And it's a pretty easy removal process? Well, I'll search. I'm sure this has been covered. Thanks! Fletch
Old Oct 19, 2005 | 12:51 PM
Z_Driver's Avatar
Z_Driver
Master
Default Wiper Arm and Motor Delete
Lowe's it's a 7/8" Hallman plug found in the spare screws and parts drawers they have right up front if your store is set up like mine. They are a black plastic and take paint well. The 1" Hallman doesn't work it is 1/32" too big.
The 7/8" Hallman goes in a bit loose but you want to use some clear silicone adhesive sealer to make sure no water gets past the plug. $1.39 for a pkg of two.
It's a 15min operation to take the wiper and motor out. And another 15min to paint and install the plug minus drying time.
I recommend getting a battery post puller and putting a little electrical tape on it to protect the wiper arm when pulling it off. Mine was really on there. I cranked on the battery post puller ****. It was getting really tough then "pop" it came right off. I thought I broke something but it was just on that hard. Some people just twist off the arm and the shaft comes out of the motor. I do not think you can use the motor again after this. I might want to reuse or give to the next owner so I wanted to spare the parts. Also, it you twist off the wiper arm you have to be really careful cause some guys have scratched their paint that way.
I have had my wiper off for about 2 weeks now and do not think I will ever have to put it back on or have the need to.
OK, I have time here's the process:
1. Take the wiper motor plastic cover off of the wiper arm and use a battery puller to take the arm off:
2. Open the hatch and take off the lower rear most interior plastic piece:
3. You'll find the wiper motor with a white plug on it disconnect that first.
Then you'll have to take out the three 10mm screws holding the motor in place.
4. Lower the hatch install your plug with silicone around it. Lift the hatch and look at it from underneath to make sure it sealed properly. If not, you can add a bead around the inside just to make sure.
5. Reinstall interior hatch plastic and close hatch.
Your done.
Old Oct 19, 2005 | 01:39 PM
EpicZ's Avatar
EpicZ
I'm not sure how much it weighs, but the motor has to be pretty strong, and those motors are heavy, the rest of the assembly is not much I'm sure.
I'm just wondering how much weight Nissan could have saved by taking it out. With no weight from the motor the entire rear hatch can be lighter...and now you are talking about some serious weight savings.
Does Nissan need it on the next gen Z? I wonder...
Old Oct 19, 2005 | 02:21 PM
Z_Driver's Avatar
Z_Driver
Master
Just weighed them on my digital scale:
1.8 lbs for wiper motor
.8 lbs for wiper arm
Total weight loss 2.6lbs.
Really, if you are thinking of doing only this as a weigh loss performance mod. Not a big gain. It does make the whole car look better but, it is not a big weight reduction.
If you need .01 to beat some guy it might just be enough. However, that is a super, super, close race. If you do it along with taking out the spare tire& tools(~25), getting lighter wheels (~40lbs). Pulling the passenger seat (~30lbs)etc... then it might make sense.
That's close to 100lbs and you might make .1 in a quarter mile run. The wheels would help even more than weight because they are rotating mass so you might see another .1-2 just for that weight reduction cause of how the weight is being shed.
If you put a roll bar in there you are back to your original weight. However, with the rotational mass down you might still pick up a .1 or .2 on the track. See how this all works?
In my case so far I have taken off the motor which was 2.6lbs and added a rear G35 spoiler (8lbs)and front lip protector (5lbs) and took out the spare and tools (~25lbs-2.6lbs =27lbs) so I had and overall weight reduction of 10lbs and improved air flow. At least I hope so .... Next I want the wheels. That is probably the best thing I can do for my car is to get 16lbs wheels on there instead of the 26lbs wheels I presently have. Then maybe a lightweight pulley to reduct parasitic (sp?) losses a little. That's another story.
$ per HP or speed gained. Not always the cheapest but it all adds up to better performance.
Hope this helps some .....
Old Oct 21, 2005 | 01:38 AM
paulsmansfield's Avatar
paulsmansfield
in a car that weighs one and a half tons, a wiper isn't going to make any difference. Anyway in Britain, it rains - a lot.
Old Oct 25, 2005 | 12:44 PM
EpicZ's Avatar
EpicZ
Great points, thanks. I guess its more important for the next Z, if they can design the car without the rear wiper Nissan can maybe save 10lbs. If the rear hatch can be lighter because it does not have to support the weight of the rear wiper.
2.5 - 10 lbs is not much but I think most engineers would love to have that much less weight. Like you said, you remove 2 here, 10 there, it all adds up.
