Placing Jack stands under control arms
Is it ok to suspend the car by placing jackstands under all the control arms? I want the car off the ground while I store it, but I want the suspension at normal ride height.
If you are storing the car for a few months, no need to put it on jackstands. That's ususally when you are talking about a year or more.
Just buy the pink insulation(the styrofoam kind, not the soft kind) and put it under all four wheels. The thing is to not let your tires sit on the cold asphalt/concrete.
My Z is stored- sitting on blueboard as mentioned by the others. This is the best solution.
I would not place jack stands under the middle of the control arms. If you were going to use jack stands- place them under the specified jack points and then raise the tires one by one and block them up. That way, the suspension is compressed as usual but without the weight of the car to support.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
