low idle after Injen Cold air intake install
Old Nov 17, 2005 | 12:59 PM
ZipidyDoDa's Avatar
ZipidyDoDa
Unhappy low idle after Injen Cold air intake install
I just installed the Injen Cold air intake on my Z and it seems as if the idle is very low, at times it even begins to shake. I say its just above 500rpm. Any suggestions on how to fix it? Has anyone had this problem?
Old Nov 17, 2005 | 03:26 PM
ANXIOUZ's Avatar
ANXIOUZ
When you say 500rpm, do you mean 500 rpm or just halfway between 0 and 1k? Halfway is actually like 600-700rpm which is "normal".
I know what you are talking about though. My car stock did the same thing. With an AEM CAI it also did it. With the JWT it does it too. I don't think it has anything to do with the intakes
How was the idle before the install?
Old Nov 17, 2005 | 04:28 PM
steela2110's Avatar
steela2110
Dude, check if everything is sealed properly, the tubes and everything... that was my problem
Old Nov 17, 2005 | 04:43 PM
MyZ4U2C's Avatar
MyZ4U2C
I have JWT on mine for over 20K miles and ive never had any idle issues at all. Just like stock. The sound however....... =)
Old Nov 17, 2005 | 04:55 PM
sisco534's Avatar
sisco534
Check for vaccum leaks, if none give it couple hundred miles the ECU needs time to adjust airflow map. Good luck
Old Nov 17, 2005 | 06:01 PM
jrod1014's Avatar
jrod1014
+1
I second checking for vaccum leaks... A leak will cause an inconsistent idle and possibly stalling out. If idle remains low, I would have someone connect a consult to it and possibly bump the idle up. I have my timing advanced and the idle set to 800-850rpm...
Old Nov 17, 2005 | 06:07 PM
FlorendoCruz's Avatar
FlorendoCruz
yyea, ive had the JWT and UTR chrome pipe and no idle problem. It feels like it was stock and love the sound it gives off. Check ur install and u prolly have the vacuum loose.
Old Nov 18, 2005 | 06:03 AM
ZipidyDoDa's Avatar
ZipidyDoDa
Thanks for all the help, Ill check for leaks to see if thats the problem. I had the JWT pop charger on it before and the idle was great, no problems. But now it idles a good amount below normal. I also give it some time to see if it is the ECU needs to adjust. Once again thanks for all the help.
Old Nov 18, 2005 | 07:00 AM
ANXIOUZ's Avatar
ANXIOUZ
So nobody's idle fluctuates? It's rock solid and doesn't waver?
Old Nov 18, 2005 | 07:11 AM
ZipidyDoDa's Avatar
ZipidyDoDa
It was pretty solid before I instaled the Injen intake.
liqalu04
Jan 2, 2022 12:58 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
