Please Help QUICK!!!
Old Nov 27, 2005 | 01:53 AM
RED HOT Z's Avatar
RED HOT Z
Default Please Help QUICK!!!
Well guys I just did the suspension and sways on my car and when I finished I turned on my car and the VDC SLIP ABS and BRAKE light stayed on. I disconnected the battery to try to reset it but nothing. It's been like 5 hours since the install but the lights are still on. What is it? What do I do?
Old Nov 27, 2005 | 09:18 AM
hndumafia's Avatar
hndumafia
might have something to do with the speed sensor wire that is attached to the shocks. did you yank on one of them and possibly damage one by any chance?
Old Nov 27, 2005 | 09:33 AM
Soccerprep205's Avatar
Soccerprep205
either that or its the brakes. if you mess with them and dont put everything back to how it was, the newer cars (like computer tech cars) will think ur Ebrake is on... im not saying to go mess with ur brakes.. but that could be it
Old Nov 27, 2005 | 10:11 AM
ZlleH's Avatar
ZlleH
You have to disconnect the battery for about 24 hours for the car to reset, or do the reset prodedure.
Old Nov 27, 2005 | 12:25 PM
RED HOT Z's Avatar
RED HOT Z
Thanks guys I will check those ideas out but whats the reset procedure^^^
Old Nov 27, 2005 | 12:48 PM
Soulz33's Avatar
Soulz33
seen here from guy an Performance Nissan about resetting the vdc after wheel size change. Turn switch on but don't start the car, roll backward 15 feet then roll foward 15 feet and this will reset the vdc. Don't know if this works but u can check.
Old Nov 27, 2005 | 12:56 PM
ZlleH's Avatar
ZlleH
http://www.technosquareinc.com/350reset.htm
Old Nov 27, 2005 | 11:11 PM
RED HOT Z's Avatar
RED HOT Z
well guys I took the Volks off and everything seems to be fine no piched wires/lines nothing. I will try to reset the system.
Thanks
Gilbert\
Old Nov 28, 2005 | 10:42 AM
RED HOT Z's Avatar
RED HOT Z
Hey guys do you know hhow much it will cost to get the problem fixed at the dealer.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
