Possibity of Fitting a V8 into a Z?
Old Jan 25, 2006 | 07:10 PM
JCA0688's Avatar
JCA0688
Default Possibity of Fitting a V8 into a Z?
I recently read the article in Car and Driver, "V-8 Witchcraft" of the Mallett Car group that installed a LS2 V8(400 HP with 395 lb-ft torque) into a Pontiac Solstice. I was just curious if anyone has stuffed a V8 into a 350Z or has ever thought about it.
Old Jan 25, 2006 | 07:11 PM
JCA0688's Avatar
JCA0688
Oh... I was just thinking. Since the SRT team is just sticking Hemi V8s into every vehicle they own, would that be possible for a Z?
Old Jan 25, 2006 | 07:12 PM
norapat01's Avatar
norapat01
I never heard about it. I think most people would just turbo'ed their Z. Cheaper and could be tuned to about 400hp.
Old Jan 25, 2006 | 07:15 PM
ZlleH's Avatar
ZlleH
Wouldn't a turbo charger give you the same if not greater gains for cheaper? I would think it would also be less complicated as well. It would also not change the weight distribution balance of the 350Z.
Old Jan 25, 2006 | 07:16 PM
JCA0688's Avatar
JCA0688
Oh yeah.. weight distribution, forgot about that
Old Jan 25, 2006 | 07:21 PM
xswl0931's Avatar
xswl0931
Top Secret stuffed the VK45 in the G35 coupe, so I'd think you could do the same to the Z
Old Jan 25, 2006 | 07:47 PM
HarvesterUT's Avatar
HarvesterUT
its possible
Old Jan 25, 2006 | 07:56 PM
J3rzeyFlip's Avatar
J3rzeyFlip
nissan titan motor swapped in a Z... insanee....
Old Jan 25, 2006 | 07:59 PM
rs350z's Avatar
rs350z
I would love to this if I ever blow the 6!
Old Jan 25, 2006 | 08:45 PM
plumpzz's Avatar
plumpzz
the LS series weighs less than most V6's... i'd like to see one of those *****es in a Z. LS1 RX7? anyone? LS7 Z? :-D 500hp/500trq NA..
Old Jan 25, 2006 | 08:47 PM
03Screamer's Avatar
03Screamer
What a coincidence...I have been thinking about stuffing a V8 into the Z. My buddy just opened a performance shop and is looking to use my car as a project car. My ideal setup would be with the LSX series motor, stroked to around 390cubes (a bit under square), have a custom flat plane crank made w/cam, solid roller valvetrain, ported LS7 heads, forged lower end of course, Harrop ITB's, Halltech EM, backed by a T56. Such a set up would be good for about 650whp NA at 7500-8000rpms. Still just wishfull thinking at this point, but I will for sure give it thought when it comes time to either FI the VQ, or throw a different motor in there later this year.
Roger V's Avatar
Roger V
Tanner Foust has it in his drift roadster. Titan engine I believe
Old Jan 25, 2006 | 08:49 PM
jakesford's Avatar
jakesford
someday down the road it might occur more often, the cost of the car offsets the number of people willing to hack it up.
Gen 1,2 & 3 RX7's you can easily swap a SBF ro SBC into
I've seen several Datsun/SB swaps
I was reading the about an LS6 swap that was done into a gen3 RX7 and after everything was done he had the car cornor balanced and the swap actually brought the car closer to 50/50 weight distro than stock. It was 51-49 front to rear and the entire car only weighed like 65 more pounds!
03Screamer's Avatar
03Screamer
Like Plumpzzz said, the LS1 is a very light motor. I can guarantee you a 427 LS7 wieghs less than a FI'd VQ, and probably just a little bit more than a stock VQ.
Old Jan 25, 2006 | 09:44 PM
twinship's Avatar
twinship
I've wondered the same thing.
Kinda surprised that isn't a "standard" mod. But then I grew up, car-wise, in the 70's, when gear heads were stuffing small blocks into Chevy Vegas.
Believe there are V8 conversion kits available for 240Zs.
Old Jan 25, 2006 | 09:48 PM
zland's Avatar
zland
Sport Z Magazine
I brought this up a couple of years ago and got blasted by posts claiming it was a dumb idea but to me if it does not weigh more thus handles well and give cheap HP, why not?
Old Jan 25, 2006 | 10:01 PM
jinsei888's Avatar
jinsei888
Tanner Foust is sponsored by Nissan North America for the Formula D drift series this coming 2006 year and it is a full widebodied dark-silver colored 350Z Roadster with a fully built Titan V8 motor, obviously that means it has been and CAN be done...with a significant nominal fee we should all assume haha
Old Jan 25, 2006 | 10:07 PM
Lightning Guy's Avatar
Lightning Guy
Similat thoughts as well. Depending on the desired end results, it coudl be done and maintain drivability. As long as it was an aluminum block and not a V12 or something and enough checkbook you could shove anything in there. Even a 20B rotary.
Old Jan 25, 2006 | 10:15 PM
350z-900whp's Avatar
350z-900whp
but, if you install V8 engine don't you have to change the transmutation,
axle,lsd....
Old Jan 25, 2006 | 10:32 PM
Lightning Guy
axle,lsd....
More than likely you will have to get a custom drive shaft and do some trick linkage for the shifter if not a servo shifter depending upon room and how far back you shove the tranny.
