Burn-out tricks for 350Z 5AT ?
Old Feb 1, 2006 | 08:01 PM
dscheers's Avatar
dscheers
Default Burn-out tricks for 350Z 5AT ?
Hello,
Does anyone have a good burn-out trick for a 5AT 350Z (TCS off) ?
(other than bying a 6M ? )
Thanks
Danny
PS: I have 6 pistons 14.25" front and 14" 4 pistons brakes back.
Old Feb 1, 2006 | 08:23 PM
StarcraftBW's Avatar
StarcraftBW
sorry but you can't
Old Feb 1, 2006 | 08:44 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
yeah just put it in neutral, redline the engine, and pull it into Drive....
...then call a tow truck and call nissan for a new tranny
Old Feb 1, 2006 | 08:45 PM
Aggro_Al's Avatar
Aggro_Al
With the OEM tires it not too difficult.
Turn off TCS/VDC. Put it in manual-mode and just floor it. With the Potenzas it's easier to burn when the pavement and tires are cooler. You might be able to get a longer burn if you brake torque while the tires are cold. You can also try to drift the car with TCS/VDC disabled and in manual-mode.
Old Feb 1, 2006 | 09:01 PM
dscheers's Avatar
dscheers
Toyo Proxes 285 in the rear...
No drifting allowed on the drag strip...
My Tanabe coil-overs are no help either (for burn out that is, they are great for traction)
I have a built 5AT transmission, so it can handle some abuse.
I currently rev. the motor to 3000 and then let go of the brakes, does spin the wheels somewhat.
How high could I rev without damaging a (normal) 5AT trann ?
Thanks
Danny
Old Feb 1, 2006 | 09:05 PM
Nitrouz's Avatar
Nitrouz
Back to Z
why do you wanna burn out on the drag strip? You're using street tires...
rolling's Avatar
rolling
Originally Posted by dscheers
Hello,
Thanks
Danny
at my track i was able to powerbrake and spin the tireas pretty good and almost smoked !!
i bet your breaks can hold ya really well!!
Old Feb 2, 2006 | 05:54 AM
cbrflyer919's Avatar
cbrflyer919
Get a line lock kit...about $50. Locks the front brakes and releases the rears. Flip the switch and floor it. Watch the pretty smoke rise.
Old Feb 2, 2006 | 06:03 AM
rolling's Avatar
rolling
ahh excellent idea!
Old Feb 2, 2006 | 06:06 AM
dscheers's Avatar
dscheers
Yes indeed, great idea. Was thinking about that but didn't realise it was so inexpensive, Thanks !
Old Feb 2, 2006 | 06:14 AM
dscheers's Avatar
dscheers
Well, my car IS a street car that I occasionally drag race.
I know I could change the rims and tires before the event, but that would deter from the looks of my car. I also want to race it "street-car". Neither do I take out my sub woofer box for example.
Traction is a major problem at the drag strips here. Burning out should give me just a little more traction, even with "street tires", right ?
Danny
Old Feb 2, 2006 | 06:47 AM
Crawgator's Avatar
Crawgator
Classic AT Burnout Tricks:
1. Neutral Slam
2. Reverse to Drive Torque Patch
3. Pouring gasoline on rear tires & throwin a match.
All will probably give you smokin tires & leave you with a fcked up car!
Old Feb 2, 2006 | 08:53 AM
bhk1004's Avatar
bhk1004
u can do better burn outs with an automatic than a manual. if anyone is interested i have videos to prove it. why someone mite ask... i was on my toyo 275 and i was shifting into 4th gear while the tires were smoking up like crazy. you have to pull the brake fuse from your car and hold down the breaks. apply gas and shift gears as u approach red line. if u rinse and repeat to often u will be in dire need of new tires very often.
Old Feb 2, 2006 | 08:58 AM
sq40's Avatar
sq40
Just pre-load it..
Old Feb 2, 2006 | 09:01 AM
bhk1004's Avatar
bhk1004
the thing is u cant just preload it without taking out your brake fuse cause i believe there is something that still works to kill the power as the rear tires are spinning thats why u need to remove the brake fuse and u can spin all you want and the full power of the motor
Old Feb 2, 2006 | 09:06 AM
sq40's Avatar
sq40
I have mad, Fishtailing Burnouts by just turning off TCS and Pre-Loading.
Old Feb 2, 2006 | 09:29 AM
bhk1004's Avatar
bhk1004
if u pull the brake fuse its guaranteed that you will have more power in the back to do burnouts and i never fishtail when I do burn outs so maybe its the fuse I dont know.
Old Feb 2, 2006 | 09:30 AM
sq40's Avatar
sq40
Could Be,, You know, You can just rig a Bypass switch for that Fuse for $5..
Old Feb 2, 2006 | 09:39 AM
bhk1004's Avatar
bhk1004
save 5 bucks and dont be lazy.
Old Feb 2, 2006 | 09:42 AM
sq40's Avatar
sq40
I could have saved $40K and walked everywhere too, but why be cheap?
