Tire Pressure Monitor Malfunction ?!?!? ---> 0 PSI
Old Mar 21, 2006 | 10:44 AM
03DB350z's Avatar
03DB350z
Default Tire Pressure Monitor Malfunction ?!?!? ---> 0 PSI
I have the TPMS on my Z, with aftermarket 19's. Have not had any problems in the past, but yesterday, the warning light goes on indicating that i have zero PSI in one of my rear tires. Not just the "--" that I know is displayed after starting the car or when using a set of wheels without the TPMS, but now one tire (and only one) shows 0 PSI. I checked the tires and all have pressure... 34+. Tried restarting the car and still shows zero.
Has anyone run into this situation before? Sounds like one of the sensors may have gone bad, but hoping that the dealer can just re-cailbrate rather than have to replace.
Old Mar 21, 2006 | 11:24 AM
jcurtis's Avatar
jcurtis
If you end up having to replace it, I have one I will sell you.
Old Mar 21, 2006 | 01:55 PM
VO...'s Avatar
VO...
Administrator
I have a new one in the box I'll sell you if you want it also. Back to your question. I have this happen from time to time with my sensors. It always clears up after driving the vehicle a few more miles. If I ever get the tires removed again I'm gonna have them pull the sensors. Those things are more trouble than they're worth.
Old Mar 21, 2006 | 02:22 PM
usmanasif's Avatar
usmanasif
Shot in the dark, but perhaps disconnect the -ve battery terminal overnight
Old Mar 21, 2006 | 03:23 PM
topgear's Avatar
topgear
My Z developed a problem with its Tire Pressure Sensor also after having a tire replaced and a flat fixed. I'm getting -- for front left, but dealer diagnostic claims there's no reading from the back left! They want to charge $140 to replace the faulty one.
I may have Firestone look at it first since they replaced the rear left tire and repaired the front left last week.
Old Mar 23, 2006 | 06:35 PM
03DB350z's Avatar
03DB350z
Thanks for the replies. Did I mention that the freaking 0 PSI error is sounding an ear piercing alarm EVERYTIME i start and drive the car. Im going to the dealer this weekend. Im still hoping this is something that can be reset....
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
