does anyone have a step by step or any info really on the traction control module found at http://www.kptechnologies.com/ I searched and couldnt find much except that it works...any info on where it installs at and if it is good quality...thanks
I have the window winder module and I can vouch for the quality, it is top notch and I have had 0 issues with it. I can't speak for the install on the TCS module though.
Is this just to give the car VDC or does it do something else? I was reading up on it but I didnt get much info...You couldnt install this if you have a base model lets say and it will give you TCS?
What this does is adds a memory to the TCS/VDC switch. Normally, if you shut off TCS, when you restart the car it turns back on automatically. This will remember what position it was in the last time you shut off the car. If you had it on, it will still be on, if you had it off, it will still be off.
