Question about shifting
Old Nov 7, 2006 | 06:03 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
the technichine at nissan told me to start from 2nd gear cuz 1st has too much power. he says to use 1st when racing or taking off fast. skipping gears from 2-4-6 is ok he said but dont know why he said down shifting is not good?
Old Nov 7, 2006 | 08:33 PM
aren21's Avatar
aren21
^you're joking right?? You should go back and slap that technitian in the face. I skip gears, but starting off in 2nd is just stupid.
Old Nov 7, 2006 | 08:36 PM
trentor's Avatar
trentor
starting in 2nd? if your Nissan dealer sold you a '72 Blazer with a 350 and a 4spd, go for it! 1st is a granny gear for climbing and towing.
this is a 350Z, not a truck with twice as much torque as HP. 1st gear is made to be used. that's why it goes almost 30-40mph instead of just 5-10.
if you're starting in 2nd, your clutch won't last as long as it should.
Old Nov 7, 2006 | 08:37 PM
Jyoder7's Avatar
Jyoder7
Starting off in second will just put excess wear on your clutch. Only do it in snow or whenever there's not much traction.
Old Nov 7, 2006 | 08:42 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i never said i do it he just told me that.. wow im getting on.. i tried after he told me but my instinct told me not to so i dont. i should go talk to him on my next visit.
Old Nov 7, 2006 | 10:29 PM
Joe2's Avatar
Joe2
Originally Posted by negotiator
The car does what it was made to do. The clutch is very loose and hard to feather. Learn to feather off slowly and you won't have problems. It's not exactly the type of clutch you can side-step.
can you explain what you mean by feather and side-step?
Old Nov 7, 2006 | 10:32 PM
Joe2's Avatar
Joe2
ask that technician what that low rumbling sound is coming from the engine when you start in 2nd from a dead stop and you're at like 800 rpm.
Old Nov 8, 2006 | 05:11 AM
Voboy's Avatar
Voboy
when i clutch in and shift, i have a 1sec pause for the rpm's to drop and then little gas, lift clutch simultaneously, and its smooth like an auto.
Old Nov 8, 2006 | 08:09 AM
Deftones's Avatar
Deftones
Originally Posted by tropicalypso
One thing to keep in mind is that you are breaking in a new clutch and drivetrain. When I got my 05, I thought that it was the hardest, pickiest thing to drive. After a few thousand miles on the odometer, things got much easier.
Be careful with the the hard 1-2 upshift tho... hit it right, and the back tires chirp, hit it wrong, and it'll grind harder then a Cambodian *****
LOL. My last gf was Cambodian. I can relate to the above statement. In fact, I think she did permenant damage. I'm still a little sore.
Old Nov 8, 2006 | 08:51 AM
bailey bill's Avatar
bailey bill
He's probably already ordered the new clutch he'll be installing soon.
bill
Old Nov 8, 2006 | 08:54 AM
bailey bill
Guys, if you don't know how to drive a manual tranny, you aren't going to learn how on a messge board.
Just go drive it. Trust me, you aren't going to hurt it.
(But pulling off in 2nd gear WILL lead to early clutch failure)
bill
Old Feb 6, 2007 | 12:16 PM
erickim080387's Avatar
erickim080387
Originally Posted by iknowitsfast
AH So THATS why i keep getting pulled over! LOL
LOL youre not supposed to pull over if u drive like u stole it. if u stole a car, would u pull over?
Old Feb 6, 2007 | 12:42 PM
350Z_LEE's Avatar
350Z_LEE
redline it then shift it!
Old Feb 6, 2007 | 01:23 PM
Cannysage's Avatar
Cannysage
skipping gears is bad practice, imo.. it actually consumes more fuel, cuz it take more power to turn the gears. don't be lazy and utilize all the gears.
Old Feb 6, 2007 | 01:46 PM
mlesnews's Avatar
mlesnews
Sure he didn't just mean, "Don't get on the gas hard in first, but drop the hammer in second." ? Like someone else said best way is to listen to the motor with occasional glances at the rpm limiter light.
Old Feb 6, 2007 | 04:05 PM
sry110's Avatar
sry110
Hey Camaro, I know what you mean. Most of the time when I press the clutch pedal in and let off the gas to shift the engine speed just seems to hang. Keeping the clutch depressed and waiting for the RPM to drop a bit before engaging the next gear is one option, but I don't necessarily like to prolong my shifting process for that much time. So what I typically do is just let the clutch out in the next gear and the tach jumps down to the proper RPM very quickly. I imagine the Z was designed with quick shifting in mind, and I just don't see how I can shift quickly while also letting the engine speed drop between gears. I guess the good sign is that the engine wants to keep going on it's own, which means you're certainly not fighting against a sluggish engine decelerating when you get into the next gear.
BTW regarding starting out in 2nd gear, if I have to slow down to a near-stop (but not completely stopping) then take off again, I will down shift into 2nd instead of 1st. The fact that the shifter doesn't seem to want to go into 1st at any speed higher than 0 makes me think that it is best to shift into 2nd in this situation. I have only ever started out from a complete stop in 2nd gear by mistake, and yeah you definitely either slip the crap out of your clutch or you try to engage it too quickly and get lots of bucking / vibration / unhealthy low tones.
Old Feb 6, 2007 | 05:01 PM
Spike100's Avatar
Spike100
Originally Posted by camaro194
I finally got the car past the break-in period and I'm not running the engine a little higher to see what kind of power it has (second gear pulls like a train!!). Is it normal for the RPMs not to drop enough while shifting? For example, say you're in 3rd gear at about 5000 rpms, and you want to shift into 4th. You would need the rpms to be around 3500 in the next gear for the shift to be smooth. Well, when I go to shift, I take my right foot off the gas, left foot on the cluth, and shift into the next gear all in a nice fluid process. But by the time I'm in the new gear, the rpms havent droppen enough (appox 500-1000 over the desired speed), and I'm not sure if I should just let the clutch out and have it take some of the abuse to match things up, or should I just wait another second so that the engine speed drops? Oh, and I still havent taken the car to redline yet, because by the time I'm going past 5000 rpms, I'm already well above the speed limit.
I read your message and the thread, and I’m guessing you have not received a satisfactory answer to your question. When you drive other high-performance cars (e.g., Porsche, “Vette,” etc.), you do not experience this problem. I think you have driven high-performance cars, and that is why you notice this problem with the Z.
First of all, your observation is correct. When shifting a stock Z at high rpm’s, the engine hangs (the rpm drops slowly). You are not the only person noticing this. There are a couple of threads on this Forum discussing this issue. Motor Trend Magazine also commented on this when testing a G-35 MT. My understanding is the slow drop in rpm’s is a concession that Nissan/Infiniti make to meet emissions standards.
The only way to fix this is installing some Nizmo components (that Nizmo states are only for racing). I’m a little surprised that some of the guys who race have not jumped-in with an explanation. --Spike
Old Feb 6, 2007 | 05:25 PM
  #38
Swiffer's Avatar
Swiffer
Thanks for bringing this one back. Yeah, it's still a problem, and I'm highly considering a lighter flywheel (although money is pretty tight right now due to buying a new house).
sry110: As for just letting the clutch go and having the very sharp drop in rpms, its kinda hard to believe that the engine was designed to do that. Feel free to convince me otherwise. I just dont want to cause any undue damage.
Spike100: Thanks for the comments. Believe it or not, I have not driven any other high-performance cars like the ones you mentioned (I wish I could!). I'm just going from observations that I have made from watching other "pros" drive and notice that there is no lag during the shift process. And the fact that I'm able to do it, but the slow-rpm-drop is holding me back.
Just wondering if theres something that I'm not doing correctly, or if it's just the car
Old Feb 6, 2007 | 05:55 PM
  #39
Spike100's Avatar
Spike100
^^ You are not doing anything incorrectly. It is a problem with the Z (and the G35 MT as well).
The problem you describe (and I would point out that your post was right-on and your valuable thread was somewhat “contaminated” by some misinformation posted by others) is really a disappointment to the driving experience that Z buyers are expecting. The Z is fairly heavy for a sports car (there is another active thread discussing this on the Forum right now), and it has a comparatively large engine. The competition provides cars that weigh less. Heavier cars need heavier components. Something else to consider: Nissan/Infiniti solved some financial woes by wisely sharing components across the various lines. That means that your Z has some Altima parts to save manufacturing costs but adds some other liabilities (i.e., weight and performance compromises).
Jeez… I wish some of the guys who race would get on this thread (your thread) and offer some suggestions based upon fact and experience. --Spike
Old Feb 6, 2007 | 06:39 PM
  #40
roast's Avatar
roast
Thanks spike, don't mind if I do.
The Z has a heavy dual mass flywheel. There are probably several other reasons why they chose dual mass, but I think a big reason is because it sends less shock through the transmission, and as we all know, Z's transmissions are not the strong point of the car.
The stock setup is easier to drive than with a light setup. So if someone is having problems shifting smoothly with a heavy setup, then going lighter probably isn't the answer. You just have to realize what you're doing wrong and get a feel for doing it right.
The fact the Z has a heavy flywheel/clutch means it takes a while for the RPM to drop to get proper rev-matched up-shifts (yes, all shifts, both up and down should be rev-matched). Since the RPM drop slowly there is no hurry to force the shifter into gear. If you're applying more force than what you could do with just 3 fingers, you're abusing the transmission. I know that may come as a big shock to a lot of people, but it's true.
Speed shifting and power shifting are both hard on clutches and transmissions. Anyone who would deny this does not know much about mechanics. Drag racing does not apply to every day driving, and it sure as hell doesn't apply to more intelligent forms of racing.
A person should work on being smooth under every day situations before worrying about racing - gotta learn to crawl before you can run.
