TOTAL $ spent on mods
Lol what do you spend 100k on? Or is it multiple setups over the years?
Bolt ons are like $5k max, FI you could say $5,000 - $20,000+?, wheels and suspension $2,000 - $10,000? Misc $5,000 - ..... 40-50K max... only a couple of cars I have ever seen on this forum are super baller like that.
I need to win the lottery it seems like or inherit some money.
My total is right around $5,000
Forged Z
2006 Nissan 350Z Roadster
Daytona Blue Touring Model
693 WHP and 650 Ft-lbs @ 22 PSI on C16
Performance:
Fully Built Long Block
Fully Built 5-Speed Drag Transmission
Greddy Twin Turbochargers
Greddy Front-Mount Intercooler
Trans Cooler
Full Fuel Return System
750CC RC Injectors
CJM Twin Fuel Pump Assembly (Walbro 255’s)
Tial Blow off Valve
NGK Iridium 1-Step Colder Spark Plugs
AAM Spec 3 inch MaxFlow True Dual Exhaust (Titanium)
AAM Spec 3 Inch MaxFlow Dual Downpipes
8000 RPM Rev Limit
Motordyne 5/16” ISO Thermal Spacer
Engine: Fully Built Long Block
Carrillo Forged Rods
ARP Rod Bolts
ARP L19 Head Studs
CP Forged 8.5:1 Pistons (.02 over)
JWT Upgraded Cams
JWT HD Valve Springs
HKS Metal Head Gaskets
Revup Oil Pump
Cam Seals
5 Angle Valve Job
Valve Stem heights Set & Cold Clearance Set
Ported Exhaust and Intake Runners
Heads Oil Passages Cleaned and Redecked
Block oil passages cleaned and Redecked
Block bored and honed using a torque plate
Crank balanced
Crank journals polished
Main and Rod bearings w/ceramic coating
Engine Management:
PRO-EFI 48 PIN ECU
Technosquare Limited Spec Reflash
Boost Solenoid
Wideband Sensor
PSI Sensor
Map Sensor
Fuel Pressure Sensor
AFR Sensor
Defi-Link Meter BF Boost Gauge
Defi-Link Meter BF EGT Gauge
Defi-Link Control Unit II
Pro-EFI CAN Gauge
Engine Bay:
Greddy Grex Front Strut Tower Bar
Greddy Radiator Cap
Greddy Oil Cap
ARC V2 Catch Can
Intense Motorsports Polished Intake Manifold
Intense Motorsports Polished Intake Piping
Stillen Carbon Fiber Engine Cover
NRG Carbon Fiber Hood Dampers
2 1/16” Koyo Radiator
Samco Hoses, Blue
Optima Red Top 12-Volt, 720 CC Amps Battery
Stereo, Interior, Exterior:
Vertex full Bumper Body Kit (Front, Rear, Sides, Wing)
Custom Painted Interior
Pioneer Avic Z1 with IPod hook up and Bass switch
Custom Fiberglass Enclosure with 2 MTX TA8500 10" Subs
2 Pioneer Rev Rear Speakers
MTX Mid and High Component Speakers
Custom Amp display with Z logo and Blue Neon Lights
MTX TA7801 4-Channel 1200 Watt Super Amplifier
TA5601 Mono Block 600 Watt Amplifier
Earthquake Capacitor, and Street Wires Fuse Box
Kinetik - 800 Watt 12 Volt Power Cell
Reverse/Backup Camera
Limo Tint
Handling:
Stance GR+ Coilovers
KSport Adjustable control Arms
Camber/Caster Alignment Arms
AP Racing 6-Piston /2pc 14.25" Rotor Front
AP Racing 4-Piston 2-Piece Rotor Rear
Driveshaft Shop 900WHP Rear Axels
Front: Forgestar F14F 18x10 +16mm Gun Metal
BF Goodrich KDW NT 255/40-18
Rear: Forgestar F14F 18x11 +23mm Gun Metal
BF Goodrich Drag Radial TA 295/35-18
...no gonna do it this time, since unfortuneately, I'm one of those
