Possible to tell if clutch is going bad?
Old May 23, 2006 | 11:28 PM
Manu's Avatar
Manu
Originally Posted by 3FITTTY
im sorry, let me get this straight... i start my car, pull up the e-brake, put her in 2nd and try to accelerate as normal but with the e-brake up? If I stall that is good, if I am able to accelerate that is bad? am i right?
Exactly, The point of the 2nd gear and e-brake is to have much resistance for the clutch to overcome. That means that if the clutch is good and grips, the engine stalls. If the clutch is shot, it will slip, and the engine will not stall. But you only do that when you want to test the condition your clutch is in.
Ayankees2772's Avatar
Ayankees2772
Ok....I stopped...put the car in second..pulled the ebrake but not to much...the car took off like if i was in first...even with the ebrake on. The second and third time i pulled the ebrake hard...and the car stalled completely both times...Than i put the car in third gear...tried to take off and it took off. Does that sound good to you?
Old May 23, 2006 | 11:31 PM
Manu's Avatar
Manu
another stupid question, if I have the clutch fully pressed in, and I rev up my engine.. That is not wearing the clutch in any way correct?
Correct. When the clutch is fully depressed, there is no connection between the engine and the transmission.
Old May 23, 2006 | 11:34 PM
3FITTTY's Avatar
3FITTTY
haha i really should not be driving a 6 speed.. nah actually i am a pretty good driver, i still just dont know all the fundamentals of the manual transmission yet.. Only been doin it now for about 8 months..
Manu's Avatar
Manu
Yes. If the car stalled, that means that the clutch is not slipping, which is good.
Old May 23, 2006 | 11:37 PM
Ayankees2772
Yea the first time i tried it...i didnt pull the ebrake hard bc i was scared...and the car started pulling and driving normal even with the ebrake on...that means my clutch is actually strong right? and why isnt it good to do this test to much?
Old May 23, 2006 | 11:38 PM
Ayankees2772
Oh and the time i tried taking off in third...i took the ebrake off...does this also mean my clutch is strong if it took off from zero in third?
Old May 23, 2006 | 11:39 PM
3FITTTY's Avatar
3FITTTY
no you want it to STALL, that means your clutch is good cause its gripping..
Old May 23, 2006 | 11:40 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
lots of newbs learning on this thread.. and no flaming so far.. wow, do i miss the old days..
this could be searched too, just so you guys know.. just saying..
Old May 23, 2006 | 11:43 PM
Manu's Avatar
Manu
Yes, but the problem is, to start in 3rd from rest, you need to slip the clutch more than you would for other gears. So it's not very good for your clutch to do that.
Old May 23, 2006 | 11:44 PM
Ayankees2772
The first time i tried it...i only had the ebrake pulled about 75%...the car took off as if i was in first with no ebrake...im assuming thats good right? the other two times i pulled the ebrake 100% and the car stalled right away...Thats means im good right?
Old May 23, 2006 | 11:45 PM
Ayankees2772
damn didnt know it wasnt good to start in third...But since it did catch and drive...that also the sign of a strong clutch?
Old May 23, 2006 | 11:47 PM
Manu's Avatar
Manu
Yes.
You don't want to do this test too often because between the time when you release the clutch with the e-brake engaged and when the engine stalls, the clutch gets all the stress. It's not catastrophical to do this test, it's just pointless. It's something I do when I'm looking to buy a used car, and I'll do it once.
3hree5ive0ero
Retired Admin
to put it simply, you will know when the clutch starts to go bad, as it'll begin to slip on you
Old May 23, 2006 | 11:48 PM
3FITTTY's Avatar
3FITTTY
slip..meaning release the clutch slower?
dump.. meaning let it out quick??
3hree5ive0ero
Retired Admin
in that case yes..
Old May 23, 2006 | 11:51 PM
3hree5ive0ero
Retired Admin
this is just my personal opinion, but I think it's better if you guys learn about manual transmissions and practice on cheap manual cars before you actually own a manual transmission car.. that way you don't make stupid mistakes..
Old May 23, 2006 | 11:52 PM
  #38
Ayankees2772
Manu check your pm
Old May 23, 2006 | 11:53 PM
  #39
Ayankees2772
Well i did practice on cheaper cars..But since the Z has a 100% different engagement point and the clutch is so stiff...It was like learning all over. Thanks for everyones help! Its so good to actually have a ? answered, instead of people saying needless things like SEARCH....
Old May 23, 2006 | 11:54 PM
  #40
3FITTTY's Avatar
3FITTTY
yeah but too late for me, ive had my 6sp Z since October.. Like i said previously though, im not a bad driver, i dont grind gears or stall ever, im just not to familiar with all the terminology..
