Clutch Clunk?
Old Jun 5, 2006 | 05:20 PM
jeff91ta's Avatar
jeff91ta
Default Clutch Clunk?
I have searched the forums but haven't found much relating to this issue. When rolling in first gear (traffic, parking lot, etc.) at single digit speeds the transmission sometimes makes a loud clunk when I fully depress the clutch if coming to a stop. A loud disengagement sound? Plus it doesn't do it all of the time, and only does it in 1st gear. Does anyone have this problem or any advice on what it might be?
It's an 06. Thanks
Old Jun 5, 2006 | 05:36 PM
Takase350z's Avatar
Takase350z
i have an 06' too and noticed that as well... not too worried about it. Also, noticed whining from either the tranny and/or rear end... not sure if its always been there or it just started... i just recently noticed it. Drives fine though
Old Jun 5, 2006 | 05:44 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
1. you haven't searched enough
2. it's totally normal
Old Jun 5, 2006 | 05:47 PM
jeff91ta's Avatar
jeff91ta
thanks for the responses.... i always find the throw out bearing threads and grinding gear threads and clutch squeal etc etc.... but this has been harder to find.
Old Jun 5, 2006 | 06:01 PM
roast's Avatar
roast
Wired, why don't you search and post the enormous amounts of information you find regarding this topic??
Better yet, humor us all and explain it yourself.
Old Jun 5, 2006 | 06:35 PM
350ztoronto's Avatar
350ztoronto
when u clutch at low rpms and let go of the gas before u clutch for more then 1 second it will make the clunk noise its nothing major most Zs have them doesn't matter what gear your in
Old Jun 5, 2006 | 07:10 PM
Swiffer's Avatar
Swiffer
Mine does it also. Its normal.
Old Jun 5, 2006 | 11:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Why don't YOU search for "clutch noise" if you think it hasn't been discussed. (Hint: it will max out search results at 500 hits)
Lots of reading material.
If you want an explanation, I would blame the chatter sound when disengaging on the dual mass flywheel, which is basically 2 flywheels in one. When one flywheel is turning at a much slower speed than the other, as is the case in engine braking, then you release/disengage the clutch, they chatter together as they go back to spinning at the same speed. The chatter does not seem to occur when you are driving at a steady speed.
This is the only explanation I could come up with. If it's wrong I'll gladly hear an alternate explanation.
Edit: Can I get an "owned" please? Thanks
Old Jun 6, 2006 | 12:19 AM
Black_Sunshine's Avatar
Black_Sunshine
No. That has to be the most implausible theory I've heard on the matter.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
