af probs...maybe
Old Jun 11, 2006 | 08:14 PM
cleanandquick06's Avatar
cleanandquick06
Default af probs...maybe
ok, check out my sig and all my mods so far. from what i hear once you do alot of breathing mods you get crazy af ratios. well i got my plx working finally and i was checking out my af ratio. i was told that 14.7 is optimal (dont know if its true) and if it is then im good. al lowest i hit 14.4 and highest is 14.8. thats all the way through the rpms, both sitting at rest and reving and going through all gears. well, not through all of 6th. thats alittle stupid on surface streets. so am i good or should i tune? and why is my car at such a good af ratio when everyone else is whining about crazy af. does it have something to do with the rev up engine?
Old Jun 12, 2006 | 12:05 AM
gsazabi's Avatar
gsazabi
14.7 optimal? LOL
That's LEAN my friend.
You should be aiming at 13. Basically anything over 13 = lean, and under 13 = rich
Anything over 14 is just too lean.
Time for ECU reflash or UTEC.
Old Jun 12, 2006 | 05:16 AM
mikead_99's Avatar
mikead_99
Actually, 14.7 is optimal for burning as much fuel as possible, so yes, it is an efficient ratio. The thing is, to make power these engines like around 13:1. You also wouldn't want it to be getting near 15 at the top of your rpm's, you would want it to be lower than 13 at the very top to protect the motor. If you want the most from your mods, go ahead and get a tune, it'll be better for the motor in the long run anyway.
Old Jun 12, 2006 | 06:53 AM
cleanandquick06
ok, well i have been watching it and every once in awhile it will hit in the 15's. what do you guys suggest?
Old Jun 12, 2006 | 09:10 AM
gsazabi's Avatar
gsazabi
Technosquare ECU reflash
Old Jun 12, 2006 | 09:12 AM
cleanandquick06
is that a one time thing or will i be able to tune it. been looking at the emanage unltimates. or am i looking in the wrong direction?
Old Jun 12, 2006 | 10:53 AM
mikead_99's Avatar
mikead_99
TS or AAM reflashes are kind of a one time thing. If you are done with mods that would affect your tune, 1 flash and your done. Both of those vendors offer a discount for subsequent flashes if you do need a re-tune to accomodate more mods after the initial reflash though. EU is going in the right direction too, but there are some cases that guys blew coil packs using it. The UTEC would be another option, but a little pricier than EU.
