Coil Over Question
Old Jun 20, 2006 | 11:03 AM
WYZIWYG's Avatar
WYZIWYG
Default Coil Over Question
I've had the car for well over a year so I'm not sure if I still qualify as a newb, but here goes:
I'd really like to begin upgrading some of the stock OEM parts on the car <mostly for better handling purposes> particularly the brakes and the coilovers. Is it possible to replace the factory shocks and springs with a coilver kit but not change the original settings? I notice when some of you guys add these on it's to either lower the car or change the suspension for autox-ing. I just want to improve the ride and handling capabilities of the vehicle, hence a suspension/brake upgrade. Just wanted to know if getting coilovers necessarily means lowering the vehicle too..
Old Jun 20, 2006 | 12:10 PM
Blue_Streek's Avatar
Blue_Streek
not at all. but i do believe that the geometry as in height of the shock/coil set-up usually is shorter than the stock set-up. another option would be to get a good spring/shock combo. something like some KYB/tokico shocks with whatever kind of spring you would want to run. that mantioned set-up would be perfect if you are not going to be attending any type of track events and just want something for civil driving purposes.
tommy
derekinthez
South East
Sep 28, 2015 06:35 PM
