Air pressure loss in tires
Old Jun 29, 2006 | 07:31 AM
Baron14y's Avatar
Baron14y
Unhappy Air pressure loss in tires
My 2003 with stock wheels and tires loses 1 - 3 psi per tire every week. Have never had this problem with any of the 5 other Z's I've had. Not talking about pressure going down when cold. This is a loss of pressure. Can't find any leaks. Is this something peculiar with low profile tires? Anyone have any thoughts as to the problem?
Old Jun 29, 2006 | 07:32 AM
Anomaly's Avatar
Anomaly
I have the same issue with my passenger side front tire. I suspect it might be a problem with the valve stem. Not certain, though...
Old Jun 29, 2006 | 07:56 AM
WYZIWYG's Avatar
WYZIWYG
I was going to post something similar but I'll just respond...
I had the same problems with the stock Potenzas, it seemed I would lose air each week. As soon as I upgraded to some Kumho all season tires, this problem has disappeared. I only check the gauge from time to time, but I haven't aired up my tires since I had these installed last fall. Maybe you should buy a better grade of tire and see what happens.
Hope this helps....
Old Jun 29, 2006 | 08:13 AM
Welcome.
All tires leak. Adding a couple of pounds each week is OK. If one tire looses, say, 5 pounds, then you may have a problem with that tire.
Old Jun 29, 2006 | 08:22 AM
mikeg8r's Avatar
mikeg8r
yeah, all tires will lose air eventually. Just buy a small air compressor for your garage and you'll be good to go. I picked one up with a digital guage and auto stop at pep boys for like $40.
Old Jun 29, 2006 | 09:11 AM
VO...'s Avatar
VO...
Administrator
One of my wheels had the same problem. I took it to Discount tire and had em' fill it with a few extra pounds of air, then submerge it in a water tub. The leak was at the rate of about 1 bubble per minute, but enough to leak out about 3 psi per week. The tech dismounted the tire and coated the outer lip of the rim with a chaulky substance to fill in all the pores. I haven't had a problem since.
Old Jun 29, 2006 | 09:16 AM
Ztalker's Avatar
Ztalker
try fill the tires with 100% nitrogen next time to slow down the leaks. Costco has nitrogen.
Old Jun 29, 2006 | 03:58 PM
uncutZ00's Avatar
uncutZ00
do you have a turbo kit? if you do, you might need to hook up the turbo to yoru tires, that way all that extra exhaust air can keep your tires going even if you have a leak. its nissan new run flat tire system.
Old Jun 30, 2006 | 07:13 AM
Baron14y's Avatar
Baron14y
Thanks for the info. That sounds like a definite possibility since the rims did have some curb rash. I'll probably live with the pressure loss since I've only got about another 5 -6000 miles on the Continentals that are on it now. When I get new tires, I'll make sure they clean up the rims and maybe put some of that unknown stuff on it to seal the pores.
Old Jun 30, 2006 | 07:31 AM
97supratt's Avatar
97supratt
They say the air we pump which is mostly carbon dioxide, a bit of oxygen and nitrogen will leak through some tires. The tire doesnt fully seal all the air, if you dont want your pressure to come down, you pump nitrogen like the big rigs do. Nitrogen stays inside the tire and doesnt leak out.
Old Jun 30, 2006 | 07:42 AM
stein's Avatar
stein
Having an air compressor is still a PITA! I have to start it up, fill the tire, then drain the compressor for 1 tire. And it's only one tires that does this not all, so not all tires do this. I suspect there is something in the tire like a nail or what not.
Old Jun 30, 2006 | 07:43 AM
bwaclawc's Avatar
bwaclawc
Yeah, my rear passanger tire leaks very slowly too. I think I will probably put on better tires, once I'm done burning these into oblivion.
Old Jun 30, 2006 | 07:44 AM
VO...'s Avatar
VO...
Administrator
I always thought Nitrogen was use because of its non-explosive characteristics. At least that what we used it for on military aircraft.
Old Jun 30, 2006 | 07:50 AM
97supratt's Avatar
97supratt
Maybe, but I remember a ad I saw in a big rig magazine that demonstrated the ability of nitrogen to stay inside the tire. It actually works because the oxygen is lighter and can penetrate through rubber through time but nitrogen cant.
Heres a good article, http://www.findarticles.com/p/articl...15/ai_97872906.
Old Jun 30, 2006 | 08:02 AM
VO...'s Avatar
VO...
Administrator
Good find.
In 1772, Daniel Rutherford discovered something that he called "mephitic air." We now know it as nitrogen. In 2003, David Connaughton has an idea regarding nitrogen. He would like to see every tire in America filled with it. Connaughton is national OEM manager of Parker Hannifin's Filtration and Separation Div. (Cleveland, OH], where, not coincidentally, they make nitrogen inflation systems. Connaughton says that as the pressurized air used to fill tires slowly permeates tire walls and escapes, it not only leads to underinflation, but the oxygen portion of the air reacts with the chemical bonds in the rubber, weakening it and reducing tire life. This can lead to a panoply of bad results, from poor mileage to on-the-road blowouts. Inflating tires with pure nitrogen mitigates many of these problems. It is an inert gas that does not react with rubber, so tires maintain proper pressure longer; and run cooler, minimizing the possibility of blowouts. Connaughton says that tires filled with nitrogen can last up to 2 5% longer, which translates into $100,000 in savings for a truck fleet of 50 with 900 wheel positions.
Old Jun 30, 2006 | 09:59 AM
mikeg8r's Avatar
mikeg8r
FYI, I belive costco uses nitrogen to fill up their tires.
Old Jun 30, 2006 | 10:27 AM
uncutZ00's Avatar
uncutZ00
replace your tires with big round blocks of cheese.
Old Jul 3, 2006 | 09:59 AM
cbrflyer919's Avatar
cbrflyer919
PLEASE BAN THIS GUY!!!!!!!! PLEASSSSSSSSSSSSSSSE
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
