Torque or Horsepower?
Old Jul 4, 2006 | 01:20 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Correct. 287hp@6200 & 274@4800
Old Jul 4, 2006 | 02:31 PM
superchargedg's Avatar
superchargedg
Damn Noobs
gentlemen and ladies,please dont respond to the totally useless post,s this person makes. all he needs to do is use the search.
Old Jul 4, 2006 | 02:35 PM
3hree5ive0ero
Retired Admin
he does start a lot of dumb threads..
Old Jul 4, 2006 | 02:39 PM
crazygideon's Avatar
crazygideon
Originally Posted by RealDeal24
Which would you raise first?
Probably the suspension. I'd like to go offroading sometime.
Old Jul 4, 2006 | 03:54 PM
bailey bill's Avatar
bailey bill
'03-'05 is 287 HP @ 6200, and 274 ft/lbs @ 4800.
Shift points should be selected that keep the engine as close to the power band peak as possible. So yes, overshooting the peak allows you fall back in a better point in the next gear.
bill
Old Jul 4, 2006 | 06:43 PM
ANXIOUZ's Avatar
ANXIOUZ
Originally Posted by uncutZ00
i'd rather have torque because my buddies dodge durango was stuck in the ditch once and i had to tow him out. i was lucky my Z has 274lbs/torque instead of the new 2006 260lbs torque...
i barely towed him out, if i would of had an 06 instead of 05 Z, he would probably still be stuck in that ditch.
after i towed him out, we did a few high way runs, all of which i beat him. gogo 287horse power to the crank!
Old Jul 4, 2006 | 10:15 PM
Bananax's Avatar
Bananax
in between. doesn't have to be white or black.
Old Jul 4, 2006 | 10:39 PM
Sunset350ZR's Avatar
Sunset350ZR
bill
Ok I believe peak TQ is at 4800 still but peak HP is 200 rpm later. Even if you do not believe that tq is broader band on 06, it is easy to see why they increased redline. If peak hp was at 6400 tpm, that would be awful close to redline. For that matter 300 rpm is close to 6500 rpm on a hard charging acceleration. Increasing redline allows more confidence to go to redline. Just a thought.
EnjukuRacing
Sep 30, 2015 06:55 AM
Dymsi
Sep 29, 2015 11:32 AM
torchkc
Sep 11, 2015 08:26 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
