Stalling.. help!
Today I stalled 3 times, all when coming to a stop. I believe it happens when i pop it into neutral and cruise to a stop.. What causes this? I remember a thread about this a while back but I could not find it, sorry..
I have 24k miles on my car and this has never happened, then today 3 times! ??
Then its still under waranty.
bill
The Popcharger has a history of this. How long has yours been on the car? If you take it to Nissan and they determine that your MAF sensor is bad, they may deny warranty coverage because you're using an oiled filter. If that's the case, the sensor is $400!!! If it goes that route, PM me and I can hook you up with a new sensor. The one I have is listed FS here:
https://my350z.com/forum/showthread.php?t=203749
Hope that helps.
Hope that helps.
LMAO!!!! Well just went out to go ahead and clean my filter, I was hoping it was just dirty and that was causing me to stall for some reason.. Well I pop the hood and what do you know my Filter is just laying there in the engine bay, who knows what the hell my engine sucked in the last couple of days!!!
You guys think i could have caused any major damage?
The worst thing that could have happened is sucking in a bunch of dirt that could wreak havoc on your internals. (my K&N always has little pebbles stuck between the pleats). Dirt can pass through the engine without any damage but it can also get wedged between the piston and the cylinder wall and gouge everything up. If damage was done it might not be real obvious, but having it looked at probably won't do you any good. If any damage was done, it's done. Just make sure you keep everything tight from now on.
