My new SSR GT3s
Old Aug 1, 2006 | 05:47 PM
Built2shredZ's Avatar
Built2shredZ
Originally Posted by Atl300zx
i dont want to compromise the ride quality, any suggestions for stock like feel with a lower stance?
Nismo Supsension w/ Nismo Sway bars, its what I got on mine and I love it...
Old Aug 1, 2006 | 05:48 PM
Built2shredZ
Originally Posted by Viffer35Z
Good to know you can move 'em....It's between the gt-3's and the Nismo's...the one thing about the gt-3, as already mentioned, is keeping all those rivets clean, the way they should be. I don't know if I'm **** enough. They are my favorite wheels though! No doubt, especially with the Brembos behind them. Also, I'd keep your exact setup, 18's with 245/275 tires. Very nice!!
Foose has a wheel cleaning kit that is like a round sponge that mounts on a tool that spins it around, it should easily clean the rivits with no problems..
Mothers® PowerBall™
The patent-pending* Mothers® PowerBall™ is the first foam polishing tool designed to revitalize billet, diamond plate, polished aluminum, stainless steel, plastic lenses, convertible top windows and much more. When used with Mothers® PowerMetal™ polish, the PowerBall™ is ideal for use on any uncoated, polishable metal finish. Its unique and durable construction compresses to fit tight spaces, so polishing difficult, intricate metalwork to a mirror-like finish is fast and easy.
Old Aug 1, 2006 | 10:33 PM
zpak's Avatar
zpak
Always great to see them Z32's...
Old Aug 2, 2006 | 12:01 AM
Mellowman's Avatar
Mellowman
Nice pics, what kind of rims are on the 300zx?
Old Aug 2, 2006 | 03:50 AM
Atl300zx's Avatar
Atl300zx
If you want the GT-3's, gotta keep your eyes opened, as they are discontinued now.
Originally Posted by TSG-Z
Looks like you have a Nissan dealership at your house!
That is actually a buddies house. We were shooting the next video for the 2007 Z Convention. Here is a link to last year's. Right Click, Save As (111MB) Although i do own my fair share of Nissans: 1990 Nissan 300zx Nonturbo, 1992 Nissan 300zx Twin Turbo, and of course the 2004 Nissan 350z Performance
I dont know if that is a good option, it says to use on uncoated metal. I believe there is a clear coat over the lip of these wheels, and the face of the wheel (around the rivets) is definately coated...with paint.
ADR M-sports
Old Aug 2, 2006 | 06:25 AM
Viffer35Z's Avatar
Viffer35Z
Built, thanks for that. Hey, could you confirm that the TPMS works with the gt-3's? Also, are there any problems with these wheels and Brembos? I've drooled over your car several times.
ATL - I checked Tire Rack and see the gt-3's are on closeout. I may have to get them this week. Just confirming TPMS, (though I believe you!) and Brembos. Also, +43 mm offset...is that too much? I was under the impression the rears should be around +30mm.
Old Aug 2, 2006 | 06:32 AM
savvy's Avatar
savvy
Those gt3's look awesome. Is that the satin or polished finish? I was considering getting some 19" satin ones but the price the seller wanted was crazy, not to mention the 90 day waiting period.
Old Aug 2, 2006 | 08:49 AM
06Firebase's Avatar
06Firebase
Cool
I have Tirerack's catalogue "Inside Track" from Spring 2006. These wheels are on page 37 and they are listed as "bright satin" and TPMS compatible.
I agree that +43mm offset seems a little high.
Old Aug 2, 2006 | 10:33 AM
Built2shredZ
I believe Tirerack.com still has the GT3's
Also the warning is about the Mothers Polish, the power ball itself is just a big sponge that you can use (without the polish) to clean the rivit areas.
Old Aug 2, 2006 | 10:36 AM
Built2shredZ
Im running with that setup on my car with the Nismo suspension and it looks pretty good.
Old Aug 2, 2006 | 10:38 AM
savvy's Avatar
savvy
holy crap your car looks nice
Old Aug 2, 2006 | 10:54 AM
ZBigDog's Avatar
ZBigDog
yo those 300s are killin it, nice wheels too.
Old Aug 2, 2006 | 12:23 PM
midniteangel's Avatar
midniteangel
NICE WHEEL! HOT Zs!
Old Aug 2, 2006 | 01:10 PM
Netko350Z's Avatar
Netko350Z
Same rims that I have on my Z...
Old Aug 2, 2006 | 01:40 PM
Atl300zx's Avatar
Atl300zx
ignore my ignorance, but higher offset means it sticks out more or less?
Old Aug 2, 2006 | 02:44 PM
Built2shredZ
Mine are satin finish
BTW, sweet looking roadster...
Old Aug 2, 2006 | 02:47 PM
Built2shredZ
Wheel offset
The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. To determine wheel offset:
Position the wheel on a flat surface and measure its overall width.
Divide the overall width by two, then subtract this result from the backspace value.
Offset = Backspace - (Rim Width ÷ 2)
The offset of a wheel can be one of the following three settings:
Zero offset:
The hub mounting surface is even with the centerline of the wheel.
Positive offset:
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars.
Negative offset:
The hub mounting surface is toward the back or brake side of the wheel's centerline. "Deep dish" wheels are typically negative offset.
Old Aug 2, 2006 | 03:34 PM
  #38
Netko350Z's Avatar
Netko350Z
I was thinking about having them painted to match the car.
I think the rim bolts would look KILLER over the daytona blue.
anyone wanna PS them for me?
Old Aug 2, 2006 | 07:57 PM
  #39
Built2shredZ
The guys at Tirerack.com said the TPM's should screw right in...
I know Stop-Tech's BBK with 14" rotors will fit with these wheels so your definatly good to go with the Brembos
Old Aug 2, 2006 | 08:05 PM
  #40
Built2shredZ
I dont know, usally when people paint there rims to match there car it can come out a little weird looking.... I'd really think about it before you do it, dem rims are not cheap...
