Tire Help- Fixa Flat
Old Aug 11, 2006 | 07:44 AM
thegr8one99's Avatar
thegr8one99
Default Tire Help- Fixa Flat
Hey guys just wanted your opinion. My tires are always leaking, and I'm always replacing them. A nail hear a nail there (i'm starting to think kids are putting nails under my tire, I don't have a garage). Its getting pretty expensive at $300 a pop. I was cool with paying the first few times but this is starting to hurt my wallet. I had to put air in a tire yesterday and already this morning My psi alarm goes off. I'm considering fix a flat or some other product. What is your thought on using that stuff.
Old Aug 11, 2006 | 07:52 AM
jers09's Avatar
jers09
I would have to say aviod Fix-A-Flat if you plan on using your Z for what its meant for, Fun sporty driving. You'd be much better served having the tire patched from the inside for $20.00 or so than using Fix-A-Flat or buying a new tire every time.
Old Aug 11, 2006 | 07:57 AM
Blu Hvn's Avatar
Blu Hvn
From what I hear, some tire shops won't touch a tire that's been treated with Fix-A-Flat. It puts a gooey coating on the inside of the tire which is extremely diificult to clean/remove thereby making patching the hole later almost impossible.
Old Aug 11, 2006 | 08:01 AM
Malic350's Avatar
Malic350
I would have to agree with jers09. I just got mine patched. Though I will say I used fix-a-flat on my 96 Camry and it lasted from Texas to California and then a couple of months in California lol - I only got new tires from american tire co. because it was time - the tire still held lol ! Not that I would try that on my ZR !
Old Aug 11, 2006 | 08:04 AM
LeMans 05's Avatar
LeMans 05
I've used fix-a-flat very successfully in my previous cars, but I wouldn't think of using it on the Z. Why don't you pick up a tire plug kit. It's relatively easy to use, and works wonders, without having the goo inside ruining wheel balance and making one he11 of a mess.
Old Aug 11, 2006 | 08:20 AM
iceman21_23's Avatar
iceman21_23
by from discount tire and get the road hazard warranty on it. 35 bucks for a new tire with a fresh warranty...
Old Aug 11, 2006 | 09:28 AM
MustGoFastR's Avatar
MustGoFastR
Fix-a Flat is fine for emergencies, but it is a big mess and should only be used to get you to a tire repair place, where it can be cleaned out and patched properly ASAP. It may also **** up your tire pressure monitors.
Old Aug 11, 2006 | 09:37 AM
Have you ever tried fix-a-flat? Its like glue. The glue is forced into the leak (by pressure) and seals it. The downside to fix-a-flat is that it literally cements the tire to the wheel.
Old Aug 11, 2006 | 12:13 PM
superchargedg's Avatar
superchargedg
Damn Noobs
also what was said above about tire shops not wanting to touch it is true.on word of caution,if you use it and then try to get it patched,you better warn them that it has fix a flat in it.the reason is it is extremely flamable and you could be in for a law suit if it sparks and catches the guy on fire.i have personally seen it happen,luckily the kid wasnt burned.
Old Aug 11, 2006 | 01:34 PM
JSON's Avatar
JSON
Discount Tire patches tires (from inside) for free.
Old Aug 11, 2006 | 02:10 PM
thegr8one99
They do this for Free???? or do I have to have the warranty with them, meaning I have to buy a new tire along with the warranty.
Old Aug 11, 2006 | 02:15 PM
LAKERSFAN's Avatar
LAKERSFAN
Are you sure its your tire this time and not your rim being bent or cracked.Seems like you are losing a hell of a lot of air overnight. I slightly cracked my rim (on my Galant) and it was leaking air. Sucked, had to fill it everytime i went anywhere for a week or so. Oh, I also tried to have it fixed. NEVER EVER DO THIS. ITS A WASTE OF YOUR MONEY. I dont care what the dude at the shop tells you. My car ran like **** after I put the "fixed" rim on.
Old Aug 11, 2006 | 03:19 PM
MustGoFastR
Yep, it's a free courtesy service.
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
