Why does everyone complain about the 350z's weight?
Old Sep 12, 2006 | 05:59 AM
  #61
norapat01's Avatar
norapat01
Originally Posted by Built2shredZ
Somone is smokin crack
the 350z coupe weight ranges from 3200-3360 depending on which model and equipment that comes with it... The Touring Roadster weighs 3600 lbs..
really?....that what it says on the door
Old Sep 12, 2006 | 08:59 AM
  #62
roast's Avatar
roast
gross weight > curb weight....
gross weight = maximum the vehicle can weigh with luggage/passengers etc...
curb weight = actual weight of car with full fluids
Old Sep 12, 2006 | 09:01 AM
  #63
norapat01's Avatar
norapat01
i think it the gross weight....gotta go check again...
Old Sep 12, 2006 | 09:09 AM
  #64
Z_freak's Avatar
Z_freak
weight watchers - a program people use to loose weight
new volk wheels - weight reduction program for Z
Old Sep 12, 2006 | 09:16 AM
  #65
bobstaff147's Avatar
bobstaff147
Originally Posted by feiji
Here's a link to an article in this month's Tuner Performance Reports. It's about weight reduction on a 350z and the benefits. There's a little more info in the mag.
http://www.tprmag.com/issue/16/light_club.shtml
Cool link.
Does anyone have similar math for calculating the benefits of lowering unsprung/rotational weight (e.g. Wheels, flywheels, etc...)
Old Sep 12, 2006 | 10:04 AM
  #66
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by Kolia
The Impreza’s white body is pretty stiff too, but I don’t think it’s has stiff as the Z’s. The sedan body is pretty much hollow.
Look at the Z’s white body construction. Integrated rear strut tower mount, a huge center cross member in the rear console plus the box shape around the fuel tank. Plus all the melt sheets (sound deadening), underbody air flow management. The car is relatively small, so chassis components must bit pretty stiff to protect the occupants in case of a crash. Thanks to some hot stamped bit here and there, it’s not that heavy.
Like some already mentioned, consider the cars MSRP of 27k and it’s impact on the design and material selection.
A Corvette Z06 is lighter. But it’s pretty much all aluminum, magnesium and has a balsa floor! The interior garnish have about half the number of mounting clips that other manufacturer uses. Hello rattles down the road (not that ours is impervious to that…).
The car feels heavier than it is in part because if it steering. That steering is heavier than most grocery getters we learned to drive in. But it’s similar to that of a BMW. Drive an NSX on day, and you’ll notice that the steering is even heavier, yet that car is relatively light and pretty nimble with it central engine.
Or drive an Elise one day. Very very light car, with quasi telepathic steering and controls. But a PITA in daily drives!
Good post.
I have read that the new Z06's fundamental mode is >25Hz (measure of stiffness or rigidity), stiff for a car, but I dont if its bending or torsion. The 612 Scaglietti body is very stiff at 49.4Hz - all aluminum body. The new Chevy Cobalt has bending stiffness of 27Hz using underbody stiffners. I dont have any comparable measure for Z or other cars.
A sedan with with a rigid roof structure can considerably increase the stiffness, its not hard to make a lightweight rigid roof structure. So I wouldnt be surprised if STi's stiffness is close to the Z. Evo also has a stiffened chassis.
Z has strut bars - front and back, rear bulkhead and underbody stiffners. I know it could be stiffer, but then you are entering into the trade studies how much it would cost for engineering to optimize it and the manufacturing costs.
On heavy steerings, isnt it just the power steering gain that affects the feel or is it the something else in the train?
Old Sep 12, 2006 | 10:08 PM
  #67
Armitage's Avatar
Armitage
My bad, you guys are right:
http://en.wikipedia.org/wiki/Curb_weight
Originally Posted by Wikipedia
Curb (Kerb) weight is the total weight of an automobile with standard equipment, oil, lubricants, coolant, a full tank of fuel and not loaded with either passengers or cargo.
This definition may differ from definitions used by governmental regulatory agencies.
Additionally, organizations may define curb weight with fixed levels of fuel and other variables to equalize the value for the comparison of different vehicles.
It is generally provided as a statistic about automobile weights, along with gross weight, which represents the weight of an automobile when fully loaded. The difference between gross weight and curb weight is the total passenger and cargo weight capacity of the vehicle.
So I guess what that really means is take curb weights with a grain of salt, because they are not held to a specific standard.
Old Sep 14, 2006 | 01:44 AM
  #68
btchnzcar's Avatar
btchnzcar
Originally Posted by btchnzcar
Has anyone tried scraping out the sound deadening tar under the carpet? I did this in my Supra, and it turned out to be about 45 pounds! I wonder if the Z is at all close to this.
Wow no one has tried this yet?
Old Sep 14, 2006 | 04:36 AM
  #69
Armitage's Avatar
Armitage
People have. I've heard of between 10-20 lbs, mostly not worth the labor it took to get it off.
Old Sep 14, 2006 | 05:08 AM
  #70
Alberto's Avatar
Alberto
Cranky FI Owner
I would never do that in the Z. I scraped the tar/sound deadner out of my old car (now my DD) and its larger than the Z. After dry icing it up and chiseling it out, I was nearly deaf and had saved maybe 10lbs. Not worth it IMO...
Old Sep 15, 2006 | 08:08 AM
  #71
ZLadie2000's Avatar
ZLadie2000
Anyone tried opening up the doors and seeing if there is a reasonable way to loose weight there? The doors are sooo heavy...
Old Sep 15, 2006 | 09:39 AM
  #72
streetracer's Avatar
streetracer
I have wondered the same thing myself. Somebody that has removed the door panel and window motor should know.
Old Sep 15, 2006 | 07:23 PM
  #73
FLZ_Boy's Avatar
FLZ_Boy
I guess I should see if that tar stuff really weighs 45 pounds in my Supra.
Old Sep 15, 2006 | 07:45 PM
  #74
n8236's Avatar
n8236
Power to weight ratio > HP. You can have 39820174 hp, but it's not gonna do **** if the vehicle weighs 100 tons.
Old Sep 16, 2006 | 12:57 PM
  #75
slinksZ's Avatar
slinksZ
This is a great thread, people may consider the Z heavy, but I had a gto, and the Z feels like a feather compared to it.
Old Sep 16, 2006 | 01:04 PM
  #76
350zz053's Avatar
350zz053
I brought my Z to jenny craig...Shes now dipping in the 2000 range....Recommended!
Old Sep 17, 2006 | 10:32 AM
  #77
Jspeed's Avatar
Jspeed
Just to provide another data point, the Z4 coupe, another 2-seater w/ a 6-cylinder engine, has a curb weight of 3100 lb., compared to 3350-3400 (depending on the trim) for the 350Z. 250 lb. is quite a big difference.
I suppose people are "complaining" because of these lighter competitions in the same category.
Old Sep 18, 2006 | 11:17 PM
  #78
Armitage's Avatar
Armitage
And a base model Z4 starts at over $50k, more than $10k for the priciest-model Z. THATS a big difference.
Old Sep 19, 2006 | 04:59 AM
  #79
Kolia's Avatar
Kolia
I guess we can find a correlation between the weight of the car you buy and the weight of your wallet after that purchase… Lol
Old Nov 21, 2006 | 02:11 PM
  #80
ihatethatbobbarker's Avatar
ihatethatbobbarker
z4s cost almost 10 grand less then $50k dude
either way, people say the Z is heavy because most people in the world, dont know what they are talking about, ive weighed my 04 base model in at 3190lbs, with stock exhaust half tank of gas, lsd and no spare tire. my wheels are pretty heavy too, but i dont know the difference between them and the factory 17s.
3200ish lbs is not alot, especially in modern times with all the safet crap, all the people that complain are damn honda kids and rx8 people that think their car weighs under 2500 lbs.
