Burnt Smell when Accelerating
Old Sep 28, 2006 | 10:02 PM
dkorr's Avatar
dkorr
Originally Posted by glowz825
I have an 06 and it has a exhaust smell when i accelerate hard....then it goes away..I dont know what causes it but I dont think it is a big issue
yup. same here. but i think its normal.
Old Oct 1, 2006 | 01:39 PM
charged's Avatar
charged
I have same issue, no big deal buts it's definitely your clutch.
Old Oct 1, 2006 | 03:26 PM
aren21's Avatar
aren21
from what im reading here, there are 2 issues. One smells like clutch/tires, and the other smells like exhaust/fuel. So both of these are "normal"?
Old Oct 1, 2006 | 04:56 PM
fowlman01's Avatar
fowlman01
I have an 03 with 40k and I've never smelled antyhing from the engine.
Old Oct 2, 2006 | 08:12 AM
conejo's Avatar
conejo
Same in my Z but mine is Automatic Transmission.
Where is that burnt smell coming from ??? I have no clucht
Old Oct 2, 2006 | 08:49 AM
Tay350z's Avatar
Tay350z
Mine is A/T also.
Old Oct 2, 2006 | 09:59 AM
suprpwr's Avatar
suprpwr
I can say I just noticed that this past weekend, too, for the first time. rev'd it hard up to like 6-7k and smelled what seemed like burnt plastic or something.
question though: is a clutch not covered under original or extended warranties?
I'm also in need of an oil change...so maybe that's what's going on...
Old Oct 2, 2006 | 10:10 AM
MechaGodzilla's Avatar
MechaGodzilla
My car does the same thing. PPW with 3200 miles. I just thought it was the cats. I would be curious if someone has the same problem with Test Pipes..
Old Oct 2, 2006 | 10:11 AM
Cannysage's Avatar
Cannysage
that's the smell of your poop in the pants, cuz the Z is so exhilarating!
Old Oct 9, 2006 | 09:48 PM
dkorr's Avatar
dkorr
The same thing happened to me too. It smells like a matchstick after you blow out the flame.
Old Oct 9, 2006 | 09:53 PM
aren21's Avatar
aren21
Hey guys, even though the burning smelll didnt smell like clutch burning, I think the smell went away after I adjusted the clutch. Weird huh, Im just hoping it doesnt come back.
Old Oct 10, 2006 | 05:53 AM
fowlman01's Avatar
fowlman01
Yeah, when cats pee on my Z it smells funny too.
Old Oct 10, 2006 | 06:38 AM
Fletch69z's Avatar
Fletch69z
Clutch?
Old Oct 10, 2006 | 08:29 AM
thilak's Avatar
thilak
I get the same smell when i rev past 5k. I think ist normal, cause my clutch doesn't slip.
Quick Questin since we on topic of clutch. When i move from neutral to Gear 1 from a roll of 10km/hour, its lil hard to put the gear in 1st. Is this normal ?, or should i completly stop the car and go into 1st ? Sometimes i avoid it by just going directly int 2nd gear.
Old Oct 10, 2006 | 09:45 AM
Spec_Tacular's Avatar
Spec_Tacular
That because it's cooler out right now. When the tranny is warm it will slide in a bit easier. The reason your car smells like that Thilak is because they probably detailed the engine before you picked it up from the dealership.
Old Oct 10, 2006 | 10:04 AM
thilak's Avatar
thilak
Tnkx for the reply, so they have some chemicals on the engine that they used to clean it with? Should the smell be gone in month or so? It didn't smell like something is wrong with it. I though its cause of reviing it.
Old Oct 10, 2006 | 12:09 PM
Spec_Tacular
Yeah it will go away.
Old Dec 30, 2006 | 05:00 PM
  #38
Burtron's Avatar
Burtron
I had the same problem, Accelerating to high RPM would yield an electrical burn smell. . . turned out my clutch was in it's final days . . . I had to have it replaced at 6,000 miles on my 06 . . . the damage was caused by power shifting too much (keeping foot on gas and shifting quick as possible) hot spots were all over the flywheel . . . I Just replaced it with an ACT clutch and prolite flywheel, smell go bye bye and car revs much faster now.
Old Dec 30, 2006 | 11:24 PM
  #39
DJMatrix1067's Avatar
DJMatrix1067
ok so i've definitly experienced this smell. smells kinda like a go kart almost lol.
but i also notice some slipping under the right circumstances.
is there any clear sign that gives away a burnt clutch? short of taking apart the tranny and looking obviously.
Should I take it to the nissan dealer and have them take a look at my clutch?
I'm thinking if i have to have my clutch replaced i will just drop the Nismo Clutch in there...how much is the new stock clutch vs. nismo clutch in terms of price.
Old Dec 30, 2006 | 11:26 PM
  #40
Forever Z's Avatar
Forever Z
I also have the exhaust smell under medium to hard acceleration in my '06. I can't remember if I had the smell before I had the headers installed. So I assumed it was maybe an exhaust leak at the headers. Now it sounds like it might be somewhat normal???
