How SGP screwed me over (*very long thread*)
Originally Posted by TruBluZ
It's easy to bash a shop that someone had a bad experience at, but when the other side of the story comes out everyone gets silent? I have never had a bad experience with ANYONE that works at SGP and Mark will tell you that my car is ALWAYS there getting upgrades. Now, I am not going to bash the OP but you must know where he came from and how many cars he tore up before getting the G to understand where most of the fault lies.
I would not trust anyone but SGP to handle my car. They have been there since the beginning and will be there in the end when it is done...GET READY!
Originally Posted by THE TECH
I'm confused as to why you would keep adding more and more mods when the cause of your issue was unknown. Also drivng the car while you knew it had issues was again your fault. SGP may or may have not done quality work, but I think some of this was your responsibility (or lack of). I would like to see what SGP has to say although most shops will do their best to CTA in order to make it the customer's fault.
Originally Posted by Poptarts
Two weeks later the car is still at SGP because every time I went to try and pick up the car it would still overheat. They were stumped as to why the car was still overheating, but I was fed up with them at this point and told them that I had to go back to Lubbock and finish school. I asked them to install the SGP torque converter upgrade as well as the SGP valve body upgrade. I also asked them to look at the car and try to fix the overheating problem without completely tearing into the motor, because I did not have the money to spend for them to take apart the motor and tell me that the heads are warped and the head gaskets are blown.
Mark and SGP have always treated me professionally....i have never even met him but I will tell you that I do have a great deal of respect for him and his co-workers. They have all been honest and even overnighted me an upper plenum when mine cracked and left me stranded...and this from a shop that I have not yet had a relationship other than a few back and forth posts on this forum....i don't know enough about the OP's situation but I am voting for Mark on this one
Originally Posted by ouch1011
This is all I needed to see. Your head gasket was already blown at this point. Don't these engines often have problems with the heads lifting under boost?
When the headgasket blew it sent the pressurized air to the coolant system.In turn with all the heat and probable 100PSI in the coolant thats how your radiator cracked.I MAY drive a N/A car a short distance with a misfire,but something that is BOOSTED??? no no no no.
I'd say its a 60/50 fault,meaning your 60% at fault.
