More noob questions
Alright thanks guys. One more question how would you go through the gears to 6 from 2. Would you start breaking then when the car hits about 50 clutch in put it 5 clutch out? so on and so forth? can someone explain this last bit of info. Thanks
Being in neutral allows you to select the correct gear to shift into when you are ready to accelerate. Why would you want to be in 5th at say 15 mph?
As far as down shifting into each gear to decelerate, I'd rather just use the brakes which are a lot cheaper to replace than the clutch is.
Like I said above:
"Quit worrying about all of the minutae. You really aren't going to hurt the drive train on any well-built modern car. Just enjoy it and relax."
bill
Originally Posted by Manu
5-4-3-2, and then make your turn into the parking lot. The gears were meant to be used this way, so don't skip them.
Oh and those who put the car in neutral, you're not saving any gas, you're increasing consumption and wearing out your brakes more
Folks, people have been driving manual trannies for about a century now, it ain't rocket science. And everyone has a little different "technique", and generally speaking, they all work. And generally speaking, a manual tranny is very hard to break, and almost impossible to wear out.
And again, you won't learn to drive one from a message board (or a book). Just go out an drive it and quit worrying.
And I doubt that anyone ever wore out a clutch shifting gears (up or down) Clutches get destroyed from slipping them on start-up, slipping them while stopped at a light, or slipping them by trying to start on a gear other then first. If you avoid those bad habits, any clutch should last at least 100K.
bill
bill
Originally Posted by rayzzee
why would you be in 5th when aproaching a parking lot? Thats a highway speed.
