my Z is buggin...i need someone to help me
Old Nov 5, 2006 | 07:42 PM
playaaa's Avatar
playaaa
Default my Z is buggin...i need someone to help me
yesterday i realized that my car is making some squeaky noisy everytime i brake to stop at the red light or when i'm slowing down. is it because my brake pads are worn out or is something serious going on? i know its not normal because it sounds so obnoxious, so i need you guys to tell me whats wrong. thanks y'all!
Old Nov 5, 2006 | 07:43 PM
kcobean's Avatar
kcobean
How many miles on the car / pads? It could just be the pads squeaking. Pretty common on the z, but hard to answer without more info.
Old Nov 5, 2006 | 07:53 PM
playaaa's Avatar
playaaa
41000 miles and it squeaks almost everytime i brake
Old Nov 5, 2006 | 07:55 PM
kcobean's Avatar
kcobean
Ok, when were your pads last changed?
Old Nov 5, 2006 | 07:59 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
change ur break pads
Old Nov 5, 2006 | 08:01 PM
playaaa's Avatar
playaaa
not so sure because i bought it used
Old Nov 5, 2006 | 08:04 PM
kcobean's Avatar
kcobean
eh....ok. Probably time to change pads then....maybe rotors too depending on condition. I recommend researching the Hawk HPS and EBC Green pads. WAY less dust than the OE pads, good braking performance, decent price.
Old Nov 5, 2006 | 08:18 PM
playaaa's Avatar
playaaa
thanks!!
Old Nov 6, 2006 | 04:52 AM
topgear's Avatar
topgear
I got new front rotors & brakes to solve this problem.
The OEM brakes had cut an ~2mm grove into the rotor.
Old Nov 6, 2006 | 11:13 AM
playaaa's Avatar
playaaa
damn...how much would that cost? not that i dont wanna spend money on my ride but i just wanna know~
Old Nov 6, 2006 | 12:36 PM
kcobean's Avatar
kcobean
It's not as bad as you think. Really if the rotors on your car have 44K miles on them, they're probably out of spec now anyway, or will be once you have them turned.
You can get all four OEM rotors from one of the sponsors of this site for under $200 and you can get Hawk HPS+ pads for all four corners from the same sponsor for under $200. A brake job on a sports car for under $400 isn't too shabby.
If you opt for slotted/drilled rotors, it can get a LOT more expensive, it just depends on what you want to spend.
