When does everybody shift?
Old Nov 13, 2006 | 08:35 AM
mndthegap1's Avatar
mndthegap1
daily driving about 3200-3400
Old Nov 13, 2006 | 08:52 AM
350 Rookie's Avatar
350 Rookie
Originally Posted by davidv
The Drift King?
Who are you?. Stop quoting me on every thread
Old Nov 13, 2006 | 08:57 AM
mavtais's Avatar
mavtais
Aargh!!! The OP is talking about when to shift to remain in "lift" mode!
The Z has a decent gear ratio, and your 1-2 shift (talking about non-rev-up 6800 rpm limiter) should be done at or 100 rpm above redline, to keep the meaner cam profile (what you call "lift") turned on. On the 2-3 shift, you will have to touch the rev-limiter because 3 is significantly taller than 2. 3-4 is a very easy change because they are very close, and this is where the Z shines (and pulls the S2000 very easily); shift close to redline, not at or past. If you have to go from 4-5, this is almost like 3-4. And if you have to go from 5-6, then man, u r 1 crazy S.O.B. or you're on the Nur./Autobahn.
Remember, peak power on a Z (non-rev up) is 200 rpm before redline.
Old Nov 13, 2006 | 01:59 PM
roast's Avatar
roast
Originally Posted by davidf
Actually most factory engines stop making power several hundred RPM's before redline and actually tend to fall off a bit before, so your pretty much wasting time going that far, if your redline is 8200 shift around 8000.
Actually you need to get your facts straight.
Show me one engine that STOPS MAKING POWER BEFORE or even AT redline.
Maybe you were confused. Maybe your mastery of the english language is not all that. Maybe you meant to say power output peaks before redline(which would be true, but contrary to popular moronic belief, that has absolutely nothing to do with shift points)
You can retract your statements or kindly insert your foot into your mouth.
Old Nov 13, 2006 | 02:08 PM
roast's Avatar
roast
I will repeat - for maximum acceleration the Z is shifted AT redline in EVERY gear. There is no going OVER redline unless you miss a shift or you have mods, and either case is not relevant to this discussion. Short shifting because peak power is made a few hundred RPM before redline is one of the most ABSURD things I've ever heard on these forums.
Old Nov 13, 2006 | 02:22 PM
VO...'s Avatar
VO...
Administrator
The Drift King?
"Do you know what DK stands for?"
"Donkey Kong?"
Old Nov 13, 2006 | 03:09 PM
davidf's Avatar
davidf
Originally Posted by DaVil03Z
Well, the celica's 2zz-GE has vvtl-i, or what we call "lift." Lift kicks in at 6800 rpm. If you were to shift at 8k, on the 1-2, you won't land in lift, so the car will lag a bit, then once you hit 6800, you'll feel that surge of power again. Unlike the 350z's linear power band, the celica's is quite narrow and all the power is made after lift. This is why everybody shifts at 8200. HP tapers a bit, but on the 1-2 shift, you can easily stay in lift.
Thank's for the enlightment, I'd never heard this, good to know.
Old Nov 13, 2006 | 09:02 PM
yahookendogg's Avatar
yahookendogg
i don't look at my rpms unless im racing but i would assume im shifting around 2.5K rpm
Old Nov 13, 2006 | 10:04 PM
350z2k3's Avatar
350z2k3
I don't shift, I like replacing engines far better than shifting.
<--never drink tranny fluid or this happens
Old Nov 14, 2006 | 04:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Redline, peak is 6200rpm's but you must go past that to land in good powerband for the next gear.
Old Nov 14, 2006 | 06:11 PM
MyZNeo's Avatar
MyZNeo
Peak HP is at 6200 - 6300 (per dyno sheet).... Set at 6500 and shift like you mean it when it lights up!
Old Nov 14, 2006 | 06:19 PM
zBoone05's Avatar
zBoone05
Default from no technical understanding...
I have little to no knowlege of the mechanical understanding behind when to shift, but in my experience, driving my Z for a little over a year, I feel no hesitation in power when I go right up to the redline.
I have felt a quick lag in power when I shift a little before, perhaps that's a reflection of driving skill, but for me, the strongest, smoothest acceleration comes at redline, even from 4th to 5th.
Old Nov 14, 2006 | 07:36 PM
Abishop's Avatar
Abishop
If it produces peak power before redline, when you shift you drop considerable amount below peak power, if you shift at redline your engine wont lose as much power in the next gear, so shift past peak HP.
Old Nov 14, 2006 | 08:00 PM
bofa's Avatar
bofa
The Drift King?
Classic
I shift when the little voices in my head tell me too...
Old Nov 14, 2006 | 09:43 PM
L33TZOR's Avatar
L33TZOR
Shift_at redline
Old Nov 15, 2006 | 08:15 AM
MyZNeo's Avatar
MyZNeo
I agree, but think this out. How quick does the mind react when the shift light comes on to send your muscles the signal to shift? How quick does the tac climb from 6300 to 6600? How long does it take to make the shift? If you wait to long you take the chance of over-reving and causing the fuel cutoff to engage. If you shift between 6200-6600 you are always within the peak power band. Thoughts?
Old Nov 24, 2006 | 11:38 AM
NewJerZ's Avatar
NewJerZ
The Celica GT-S DESPERATELY needed a TURBO....IF it did (and a short shifter), I just MIGHT have bought one!
Old Nov 24, 2006 | 11:42 AM
  #38
BlackZero6's Avatar
BlackZero6
^ the celica need a turbo and awd....we need another gt-4 ...oh well
anyways....
shift_when sun and moon align...as the wolf howls at the stars.....
Old Nov 24, 2006 | 11:51 AM
  #39
SoulDesign's Avatar
SoulDesign
ok. correct me if im wrong, but "lift" on a celica gts is the sme thing as v-tech...or even mi-vec on mitsubishis.....right? the z does not have variable cams. so as someone said...."he wants to stay in wht he calls 'lift' " ....... that doesnt even apply to a z. he's just wondering when to shift to have the fastest acceleration possible.
Old Nov 24, 2006 | 01:16 PM
  #40
DaVil03Z's Avatar
DaVil03Z
Exactly! I was simply explaining that everybody on the celica forums shift at about 8200 (right before fuel cutoff) despite the redline being at 7800. They do this on the 1-2 **** so they can land in "lift" which starts at 6800. I just wanted to know when the best time to shift is, since the Z has a totally different powerband (at redline, a lil above, a lil below). Thanks, though, for all the advice guys.
