Quick Stupid Question (Will Delete Thread After Response)
Old Dec 1, 2006 | 09:08 AM
On Nightfall's Avatar
On Nightfall
Default Quick Stupid Question (Will Delete Thread After Response)
Ok, I’ve owned two sedans before the Z, never owned a coupe. especially one without rear seats. The days that it rains, I can almost hear every bit of water I’m splashing in the rear with my tires inside the car from my seat. I can almost bet this is normal but I just want to make sure.
P.S. I searched and jesus, everyone and their mother has noise issues so I couldn’t find anything through the billion noise threads.
Old Dec 1, 2006 | 09:10 AM
reptile718's Avatar
reptile718
completely normal, the Z sits fairly low to the ground
Old Dec 1, 2006 | 09:12 AM
savvy's Avatar
savvy
yep its normal....unless you start seeing water coming into the car
Old Dec 1, 2006 | 09:14 AM
THE TECH's Avatar
THE TECH
What an odd question.
Old Dec 1, 2006 | 09:15 AM
dbasal's Avatar
dbasal
Normal. It is a good warning too that you should be a little more careful with this car. Too many bad things happen when you drive it hard in the rain.
Old Dec 1, 2006 | 09:17 AM
Built2shredZ's Avatar
Built2shredZ
Just read another thread that said there are open holes in the trunk area, if you lift your carpet up you will see them. Someone posted that in Japan Nissan has to put some sort of jump seat back there so that's why the holes are there, but they didn't bother to plug them for the North American models, which allows extra noise to enter the cabin. One member sealed them and put dynamat over the top of it and has said the noise level has dropped quite a bit
Old Dec 1, 2006 | 09:35 AM
Driven1's Avatar
Driven1
Professional
It is normal, if you want to deaden the noise, Dynamat behind the seats (inside the cubby's/factory sub opening and glovebox) and in the trunk.
Old Dec 1, 2006 | 09:42 AM
MasterRacer's Avatar
MasterRacer
yep like everyone else has said, its normz! Just becareful driving in the rain
with those crap Potenzas you'll spin out in no time flat.
Old Dec 1, 2006 | 09:44 AM
There is no such thing as a stupid question.
There again there is an exception to everything.
Old Dec 1, 2006 | 09:51 AM
6894kevin's Avatar
6894kevin
If U Dynamat the entire floor pan, under all the carpet, how much weight would that add????
Just wondering because I heard that stuff was heavy
Old Dec 1, 2006 | 10:22 AM
usmanasif's Avatar
usmanasif
But there are plenty of inquisitive idiots!
OP, not you Don't worry about the sloshing noise unless the car fell off a bridge a second earlier.
Old Dec 1, 2006 | 11:03 AM
sanf's Avatar
sanf
this one is by far one of the best odd question and it's nowhere near stuipd.
Old Dec 1, 2006 | 11:06 AM
On Nightfall
haha, why is it so odd? and thank you guys very much for your quick responses and being very positive. I was expecting to be banned and flamed.
Old Dec 1, 2006 | 11:11 AM
Driven1's Avatar
Driven1
Professional
It is heavy considering its a mat like material and has the consistancy of 3M stip caulk. Honesty, the weight is unnoticable.
Old Dec 1, 2006 | 01:00 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I did spray on undercoating in the wheel wells on the sheet metal and fatmat in the trunk area, I don't hear the rain anymore.
Now if I can figure out where my headliner rattles, I will be in business.
Chris
Old Dec 1, 2006 | 01:42 PM
zzz350's Avatar
zzz350
IF you think the water makes noise, just drive thru a little road gravel if you want to hear noise in the wheel wells.
LOL. The noise is typical of a hatchback:
There is no rear seat to muffle road noise.
Essentially the wheel wells are 24-inches from your ears.
Nissan do not pack the 350Z with an additional 100 pounds of sound deadening material.
Old Dec 1, 2006 | 02:24 PM
On Nightfall
Thank you David, guess I just have to crank the music up!
Old Dec 1, 2006 | 02:50 PM
ericjackson's Avatar
ericjackson
the noise i cant stand it the rearview mirror rattle. ive tried and tried, that is the only rattle i still have
