Ran the Z on the G-Tech Today
Old Dec 26, 2006 | 10:45 AM
filmnews's Avatar
filmnews
Default Ran the Z on the G-Tech Today
I ran the G-tech earlier today. I ran the 1/8th mile once, and I had traction control turned off. was able to run a 9.36 in the 1/8th. I had a 60ft time of 2.44. My 0 to 60 time was 5.69 seconds. I was not able to launch over 1,000 rpm because I would spin. I had to ease into the gas. The car currently has 225 tires on the back. This is a pretty good time with no traction. I will be getting new tires and wheels this spring. I think that my car could get in the 8's with some good traction. It was 34 degrees outside.
Old Dec 26, 2006 | 11:13 AM
HDPDZO6's Avatar
HDPDZO6
Why would someone put 225's on the rear of their Z?
Old Dec 26, 2006 | 11:18 AM
filmnews's Avatar
filmnews
That is what is on the back of my 2005 Enthusiast. I got the car used with 12,000 miles on it.
Old Dec 26, 2006 | 11:35 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Wait a minute... So you're saying that you did 0-60mph in 5.69 seconds with a 60' time of 2.44? That doesn't sound right. I don't believe that. With that logic, I'm doing about 5 seconds to 60mph whenever I cut 2.0s 60' at the drag strip. I always wondered how accurate those things were..
Old Dec 26, 2006 | 11:39 AM
Fletch69z's Avatar
Fletch69z
Isn't 225 the width of the front tires?
Old Dec 26, 2006 | 11:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You should have a 235 series IIRC.
GTECH's are decent, Id say the 1/8 is correct, the 0-60 sounds a little too quick for your 60ft, but its close....btw trying speed runs in 34 degree weather on 225's is retarded lol
Old Dec 26, 2006 | 11:47 AM
I would not even attempt timing myself when the temperature is 34 degrees. Still I guess that the G-Tech thing is fun.
Old Dec 26, 2006 | 11:50 AM
Ztalker's Avatar
Ztalker
it happens when the Z's tires are rotated by mistake.
Old Dec 26, 2006 | 12:01 PM
TTNosZ's Avatar
TTNosZ
9.3!!!! wow... is it stock...? i ran a 8.8 stock but.... my conditions wernt as bad... i had traction and it was like 110 outside STicky
Old Dec 26, 2006 | 12:04 PM
filmnews's Avatar
filmnews
It is bone stock right now. I will be getting a spacer and intake soon.
Old Dec 26, 2006 | 12:20 PM
filmnews's Avatar
filmnews
I just checked my tires, and they are Toyo Proxes TPT 225 all around.
Old Dec 26, 2006 | 12:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Curious what you ran down the 1/4 and what your 60ft was. I hope your reffering to a real track and not a GTECH btw..
Old Dec 26, 2006 | 12:25 PM
It’s a bit of an unusual set-up but no big deal. The 17-inch rear OEM tires are only 235mm wide.
Old Dec 26, 2006 | 03:41 PM
hardrock905's Avatar
hardrock905
It's a big deal if you want any kind of real traction. I would definitely get wider rubber, at least in the rear.
Old Dec 26, 2006 | 04:17 PM
HDPDZO6's Avatar
HDPDZO6
Wonder if the OP got his hands on a Z used extensively for drifting... How unfortunate.
Old Dec 26, 2006 | 04:25 PM
1.98 second 60-foot time on 235mm street tires. Some might consider that real traction.
Old Dec 26, 2006 | 04:33 PM
Question
Nice numbers. Post a time slip.
Old Dec 27, 2006 | 12:12 AM
ZSpectrum's Avatar
ZSpectrum
arnt those toyo proxes supposeds to own. My friend who does stuff with a porsche race team uses those tires.
Old Dec 27, 2006 | 05:48 AM
hardrock905
OP has 225's.
Old Dec 27, 2006 | 06:47 AM
OP has 225's.
